Go Back   VAF Forums > Regional Forums > Texas (North)
Old 03-23-2018, 10:01 PM
PBell PBell is offline
Default Greetings from a newbie and another 9A underway
Howdy, I took delivery of my tail section on Wednesday. Inventory revealed two damaged rudder skins, new skins coming. Also my plans had RV8 HS and rudder plans (no 9 plans). So I started the VS first. I?m at 9 hrs on build time and will prime tomorrow.
Been a long time lurker and have come out. Great info here, hopefully I won?t burden with too many questions. Posting pics on pbell1733.wordpress.com
PBell - 92293
N393RV reserved
2021 donation made
http://myrv-9abuild.com
Old 03-23-2018, 10:18 PM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Welcome aboard. VS is a good place to start anyway. Might as well order an extra elevator trim tab skin while you are at it, takes a couple tries on the bending good luck, let me know if you have any questions.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 03-23-2018, 11:56 PM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Default Welcome to VAF
Paul, welcome to VAF
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-24-2018, 02:57 PM
N941WR's Avatar
N941WR N941WR is offline
That is a good suggestion to start on the VS rather than the HS. It is easier to build and will allow you to gain confidence.
Pay attention to your air pressure when riveting. Here is a link to suggested air pressures. They are much lower than you would expect.
Also, you might want to think about dropping the "A" and put the little wheel on the proper end. Also, when it comes to select a primer, pick the best one. Oh, and don't forget that if you pick a slider, it is probably the wrong choice and if you go with a tip-up, it too is probably the wrong choice.
Good luck and enjoy the journey!
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 03-24-2018, 04:04 PM
dwranda dwranda is offline
Welcome!! You're in the right place. If it wasn't for VAF and peoples various build sites there is no way I would be doing this.
9A in progress
Working on Finish kit!!
Mattituck TMXIO-360 red gold
Dues paid April 2021
