Old 03-22-2018, 08:19 PM
Charles in SC Charles in SC is offline
Default Engine movement question
How much does an engine move at the rear vs the prop end. I have a IO-360. The reason I ask is that the stainless oil line on the co-pilot side that is the line to the prop is about 1/2 inch from one of the engine mount tubes. I do not think it moves much at the rear but wondered if someone can confirm this. Thanks in advance!
RV 7
Old 03-23-2018, 07:05 AM
rvsxer rvsxer is offline
That line is always tight going through there. 1/2" should be plenty. Just check it for any signs of chafing after it's run a bit. That's what I did.
Mike Hilger
RV-6 N207AM w/G3X, 1,600 hours +
South St. Paul, MN (KSGS)
A&P, EAA Tech Counselor
We're all here because we're not all there...
