Old 03-20-2018, 09:23 PM
Draker's Avatar
Draker Draker is offline
Default Skin corners: To round or not to round?
Looking through a variety of build logs, I see some builders round the corners of their sheet metal skins, particularly ones that overlap other skins, with a significant radius. Others simply debur but leave the corners square. I failed to find any guidance from Vans in the construction manual about which way is correct. Maybe I didn't look closely enough. Is the choice to round skin corners merely cosmetic, or is there a good structural reason to do it? Or is this a religious war that I dare not start?
Old 03-20-2018, 09:41 PM
Ironflight's Avatar
VAF Moderator / Line Boy
I very rarely leave completely square corners on any part, especially sheet metal panels, if for no other reason that they snag things - clothing, rags, hands..... If you can’t run your hand over it without fearing impalement or a cut, You should round it off or debur it some more.
How much? It’s an art!
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-21-2018, 04:46 AM
mike newall's Avatar
mike newall mike newall is offline
And there is a correct method to rounding corners with a file
I may be persuaded to upload.
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 03-21-2018, 05:36 AM
Reflex Reflex is offline
Mike,
Please consider this a plea for an upload. Always interested in basic blocking and tackling. Seems pretty basic to me, but if there's a correct method, it means that there's also an incorrect method.
Always looking to learn.
Fred
Dues Paid for 2020
RV-14
Empennage Complete (including fiberglass)
Wings complete (including fiberglass)
Fuse joined and working on painting interior
Old 03-21-2018, 06:18 AM
OK,
This is one technique, many others are available, but it does give consistent radiused corners. The thing is you start where you normally finish, if that makes sense...
https://youtu.be/a4fVHgQGCqU
Donated in 2020
Old 03-21-2018, 08:57 AM
That technique works fine for larger ones, too.
Dave
