10-22-2019, 05:29 PM
it seems most of my go-arounds are after flying relatively long 3+ hr flights. why is that? I'm aware of it now and try to manage it and fly the numbers.
Steve Melton
Cincinnati, OH
www.rvplasticparts.com
10-22-2019, 06:25 PM
I also find that my landings after really long legs can be sloppy...it?s probably just fatigue. Long legs involve more serious navigation, more radio changes, more varying weather conditions etc. Now I?m aware of the problem I also make an extra mental effort as I approach.
It?s interesting that the ATSB report said the plane didn?t have its wheels fully on the ground and commence its landing roll until 125 metres from the end of the runway....that?s quite amazing. Apparently it bounced several times before that point. The strip was only 690 metres in length and largely surrounded by trees.
You’re only as good as your last landing
Bob Barrow
RV7A
10-22-2019, 08:42 PM
My surprise was that at 45 mph at the last measurement and so little damage the guy didn't make it. His seat harness worked but his head went forward. I thought at that speed the chances were better. Very complete report and a sad ending.
rockwoodrv9a
Williamston MI
O-320 D2A
Awaiting DAR Inspection
10-22-2019, 09:16 PM
I am the same. After a long cross-country I tend to be quite tired. I was talking to a former Qantas pilot a couple months ago - at Somersby ironically - and he mentioned the effect blood sugar levels can have and that he made a point to have a sweet snack before descent or prior to takeoff.
I don't know enough about the physiology of it, but it makes sense when you consider how quickly jelly beans can positively affect a diabetic. Could be worth trying - if only to give you an excuse to add a packet of 'em to the shopping...
Once you have tasted flight you will forever walk the earth with your eyes turned skywards, for there you have been and there you will long to return - Leonardo DaVinci
My Flickr gallery: http://www.flickr.com/photos/35521362@N06/
RV-9A - Finished on 10th February 2016 after 4 years, 9 months and 19 days! The 1020th RV-9 flying.
First flight 26th March 2016. Essential specs 145KTAS @ 2400RPM, 8000', 24.2LPH, Initial RoC 1800FPM.
10-23-2019, 04:00 AM
Sad
I?ve flown my 7 in there a few times. It?s not one of my favorites.
The length isn?t overly challenging. But the surface isnt great and the slope especially needs respect in that direction.
What it has in common with other considerably shorter 1 way strips I regularly use with fences/trees/power lines/channels/drains whatever, is that it needs a decent self brief, no matter how many times you land there.
Fatigue may well have been an issue and as much as remaining well fed and hydrated is important, a proper plan is essential when landing long or an overshoot is unacceptable.
For me, all 3 wheels on the ground and on the brakes by half way or around we go. RVs are capable of landing pretty much anywhere if done right. It?s being prepared and ready to act when things aren?t right that?s important.
It?s all very sad. I met Richard quite a few times. Lovely guy.
Richard
RV7 VH-XRC Sold :-(
RV10 in progress.
Sydney, AUS
10-23-2019, 06:28 AM
I think you are always better off landing in to wind, even if it is down hill. You just have to concentrate on speed and aiming point and have a planned touchdown point beyond which you go around. A headwind is your friend. There are 2 airports in the my area with steep slopes, more than 2% and they can be tricky, but so can a tailwind. If it is blowing 10 kts on your tail are you still going to land uphill? Have you figured out how much more distance you would need? That?s 20 kts more ground speed than going the other way. That?s a huge amount of energy.
This guy left it too late, which can happen to anyone. We?ve all landed long but usually there is a bunch of pavement in front of us so we don?t worry about it. This guy didn?t have that option. Very unfortunate and a wakeup call for the rest of us. I hope he makes a full recovery. Tough at that age.
Scott Black
VAF dues 2020
Instagram @sblack2154
10-23-2019, 07:30 AM
I do a lot of long cross-country legs, many in the 5 and 6 hour range, and I've noticed the same thing. I carry trail-mix type snacks enroute and sweets for the approach phase, it definitely helps me. Flying long legs is not physically tiring, but it's mentally draining.
10-23-2019, 08:58 AM
Just want to share my decision point on go arounds for a few of you and hopefully it will help someone.
Determining to go-around point is a critical (and in some cases life critical) decision and unfortunately there is rarely a clearly defining moment when a go-around in necessary (deer, etc.).
For those of us who fly regularly, we're going to make decent approaches and have the ability to correct them. That also means that our go-around decision point is likely going to based in a gray area. Our approach will be close to good, but it will be marginal. Is it marginal enough that you need to go around?
For me, my decision point is simple. The first time I think, "you might have to go around on this one" is my decision point. Yeah I can rescue 99.999% of those landings, but my decision point is when that initial thought of a go-around is developed in my head.
The beauty of it is that there is no gray area. Is this approach good enough? Can it be salvaged? What can I chance to salvage it. Etc.
I've already made my go-around decision while sitting in the recliner and now I just have to execute it from the front seat of the airplane.
10-23-2019, 09:08 AM
Can it be salvaged?
I would submit that if you are questioning whether the approach can be salvaged, you probably should probably be doing a go around...
Go arounds are free; why try and salvage a poor approach?
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
10-23-2019, 02:51 PM
I think that is a really good point. To break off the approach and have another crack at it, particularly at an uncontrolled airfield, takes at most, 5 minutes. I can do a full circuit to 1000AGL and back to the runway for another T&G in 3.3 minutes, so it isn't like you're going to be significantly delayed by going missed.
Getting down in one piece is the goal. Getting down off the first approach is a bonus.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
