Originally Posted by Andrew Anunson
It doesn't exist (or at least it shouldn't) for a good reason.
I don't think a Both setting makes sense with a duplex valve (valve with returns). Where is the return fuel going to go when you have the valve set to Both? It might go to the left or to the right... you'll never really know.
If you are going to run a system that requires a return (such as EFI) then you need to be in control of where the return fuel goes (which should be the tank it came from).... therefore you need a Left / Right valve.
Bob says (Patrol Book) if using a L-R fuel selector, take offs and landings should be made with the tank at least 1/2 full and no significance slip to avoid unporting the selected tank. I would make that a limitation in my airplane.
I know you don't want to use a header tank. You might consider the simplicity it can give though. Weighs less than 1/2 a tank of fuel. Allows for a simple on-off fuel selector valve.
I look forward to seeing what you decide.
