Old 03-18-2018, 12:54 AM
fairchild fairchild is offline
Default recommended rubber for rib pressing
Hi all---
I am making nose ribs in my hydraulic press with a thick rubber pad.
They are coming out very nice except the my lightening hole flanges are
not quite turning over (bending) quite enough. I THINK my rubber isnt
quite extruding down into the hole far enough to full bend the flange to
30 degrees. I am thinking I need a slightly softer rubber. I think my current
rubber is some kind of carbon type rubber----- but I have read that a
polyurethane version is the best performing kind for this application.
Can some one advise me what durometer and thickness that is good ?
(Im actualy building a bearhawk--- not an RV---- but dont tell anyone ! )
Bob admits that he "stole" the RV's wing construction style because he
he must have thought it was so sensible....
Thanks ahead of time for any guideance.
Tim
Old 03-18-2018, 09:37 AM
dpansier's Avatar
dpansier dpansier is offline
I have used sections of Truck inter tube with success, flows into the smaller areas and gives good part definition.
Don Pansier
Green Bay, WI (GRB)
RV-7 N450DP
W9LYX
Antennas for Experimental Aircraft
www.deltapopaviation.com
Old 03-18-2018, 11:57 AM
vfrazier's Avatar
vfrazier vfrazier is offline
Originally Posted by fairchild View Post
Hi all---
Tim
How many tons are you needing for a nose rib?
Vince Frazier
www.f1aircraft.com
F1 Rocket and F4 Raider components
1-888-F1AIRCRAFT (1-888-312-4727)
www.flyboyaccessories.com
RV and Rocket Accessories, Tailwheels, Tools, & More
1-888-8FLYBOY (1-888-835-9269)
F4 Raider - under construction
F1-H Rocket "Crazy Horse" - sold
RV-4 "Chief Pontiac" - sold in 1994, purchased in 2018
Old 03-18-2018, 12:45 PM
rv7charlie rv7charlie is offline
What dpansier said, on top of the rubber block. I assume you've seen these?
http://www.eaavideo.org/detail/video...t-hydroforming
and
https://www.youtube.com/watch?v=xw5yEMsDxR8
Old 03-18-2018, 06:48 PM
Default hydroforming details----
yes I have watched both of those videos-----
I have 2 rubber chunks--- each 11 by 14 inches and 2 inches thick.
My jack is 20 tons---- but I may go bigger----
It is working really good except I need a tiny bit more extension of the rubber
through the lightening hole cavities to roll the flange a bit more.
My rubber is unknown hardness but looks like very close to car tire durometer-
Tim
Old 03-19-2018, 11:48 AM
vfrazier's Avatar
I haven't tried them, but farm supply stores often sell thick rubber mats that sure look like a cheap source of easily sized rubber.
Vince Frazier
www.f1aircraft.com
