Best bet, if you can find one, is a piloted reamer. First drill under size, (with the guide block), and then use a piloted reamer to final size.
Ask around your local EAA chapter---------hopefully you have one, for the reamer.
Reason to ream instead of just drilling, is hole is ROUND, and a proper fit to the bolt shank.
Good luck.
Mike
