03-17-2018, 10:30 PM
I am pretty sure mine is a Bruce?s cover and I?m very happy with it, I know the club planes I fly have Bruce?s covers too and they are really nice covers.
Proud owner of 925RV
Special Thanks to Fred Stucklen
While I'm not a builder if I happen to give advice , I will not be responsible for damage to equipment, your ego, parts, world wide power outages, spontaneously generated black holes, planetary disruptions, or personal injury that may result from the use of this advice.
03-18-2018, 01:06 PM
Abbey?s cover
I?m fortunate because when I bought my 7 a Flightline cover came with. Fits well, holds up well and is light weight. Only use it traveling since my RV7A is normally hangared.
Jim Harris, ATP, T38, EC/KC-135A/E/R, 2008 RV7A, 2nd owner, N523RM (2015)
Superior XPIO-360, Hartzel CS prop, Aerotronics panel with Dual GRT Horizon WS, EIS, Garmin 340, 335 w/WAAS gps, Dual 430s (non-WAAS), TruTrak 385 A/P with auto-level, Electric trim, Tosten 6 button Military Grips, FlightBox wired to WS, Dynon D10A w/battery backup, 406 MHz ELT. Custom Interior, New TS Flightline hoses, Great POH!
Retired - Living the dream - going broke!
03-18-2018, 05:28 PM
Have been thru a few, first Van's then Abby's, Abby's lasted quite a while but finally wore out, have had the light weight Bruce's for about a year now, really like it compared to the others but it does come at a bit of a weight/size penalty.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
06-05-2018, 10:53 AM
My question is whether any of these covers can scratch the canopy. Abbys cover is lined with a nylon ripstop type material, with exposed seams. Bruce's is lined with a microfiber. Has anyone had an experience with canopy scratching, caused by their cover? Thank you!
Greg Novotny
RV-14a 140209
80 hours, running strong
Tacoma Narrows
06-05-2018, 11:02 AM
Cover
Got mine from Van's light weight and great for traveling.
Bob
06-05-2018, 01:55 PM
I had a Bruce's Custom Cover for my RV-8 many years ago and it was a fantastic product. I'll be ordering a cover from him for my RV-14A at the appropriate time.
Ken
RV-8 N118KB (#81125) - Sold
RV-14A N114KB (#140494) - Sold
RV-14A.com
N114KB Build Site
06-07-2018, 12:41 PM
canopy scratches
I have a nice fitting cover that is ripstop nylon. It is not Abby's. It works great as a hangar cover, but I have had some problems when the plane stays covered for several days while on the road. Most notably while in Moab with 2 days of pretty significant wind and off course blowing sand. Fine grit gets under it and leaves the canopy a bit milky. Easily polished out. The areas with seams are more noticeable.
It seems that no matter what is under the canopy, dirt and grit will make its way under and any movement would cause scratching. The cover is tightly secured. Considering using mylar bubble wrap type sunshades inside instead.
Eric Wiley
RV-8 finished 9/15
Flying S Air Ranch (10XS)
Brownwood TX
06-07-2018, 01:43 PM
airplane-covers.com
Weather Max from Mac’s Airplane Covers, LLC. Fully lined for RV canopies. It's not listed on their website but you can ask for it. Very light.
Cost was $264.95 plus s/h $18.85 about a year ago. They offer others for more but the full liner is an extra $100.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
06-07-2018, 05:17 PM
Greg Novotny
RV-14a 140209
Tacoma Narrows
I've heard the same thing from an FBO in southern AZ. They don't recommend leaving the canopy cover on if there's blowing wind and sand...which is pretty often. Might be better for non-desert locations.
06-09-2018, 11:29 AM
Anybody got a tip with regard to Bruce's standard vs light weight cover? Especially for an RV-10.
Maxwell Duke
Kitfox S6/TD/IO240/SteamIFR Built it
RV10 IO540/AFS5600x3 Bought it
CH750 O200/AFS5500. Built it with 7 friends. DAR-Vic Syracuse
Maule M7-235C Sold it(kind of miss it)
VAF paid 5/2017
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
