Originally Posted by az_gila
Is all of that work (and risk) worth it for $2.19?
I don't do this to save $2 and if I have one available always use a new one. However, crush washers are often difficult to source locally and when I don't want to wait three days for delivery, I improvise. Actually, It's not a lot of work; Takes about 3-5 minutes. I also often make crush washers from .063 stock, but in this application washer height is a critical dimension, so I didn't suggest it.
I don't see the risk of re-annealing a crush washer for re-use after insuring dimensional accuracy and annealing, other than the small loss of washer height. Maybe you can enlighten me on the risk of this method. I have done about 20 of these (mix between home-made and re-worked) on our family cars and not one has leaked or come lose.
I know many consider me a heretic for proposing such a path and I understand many think it's a bad idea. However, I posted it for all to read and I am sure some would find it worthwhile tip, especially when making repairs far from home.
Larry
