Old 03-13-2018, 08:45 PM
rjkulesa@gmail.com rjkulesa@gmail.com is offline
Default Here goes nothing...
Well it?s official.
Van?s Builder Number 140477. Empennage kit ordered.
So it begins.
Due in a large part of the all the support from my Family, the EAA SportAir Workshop, Webinars, Homebuilt Help tips, Chapter 643, the Mothership, and of course VAF - I feel (barely) able to take on a project like this. There is SO much to learn and decide, but it?s a blast diving in the past few years and preparing.
I?m humbled by all those, including many of you here, who have come before and blazed the path. It?s inspiring.
One day I hope to know what a roller tapppet is and what?s so special about them
Warm regards,
Rich Kulesa
Old 03-13-2018, 08:54 PM
kaweeka kaweeka is offline
I'm envious, Rich. I purchased my aircraft already flying. I did do the paint, avionics and interior but someday (when I'm not working 12 hours a day) hope to enjoy what you are about to embark upon, and feel the unmeasurable pride of building your own aircraft. Best of luck and Godspeed.
David
RV-9A N435KR, Vans calendar March 2018
LIO 320 B1A, Dual LS Plasma III, AFP injection
G3x touch
Roseville, Ca
Old 03-13-2018, 09:20 PM
KeithB's Avatar
KeithB KeithB is offline
Welcome to the RV-14 journey. If you are like me, it will be one of the most enjoyable and rewarding things you undertake - ever! The RV-14 kit makes this incredible process about as good as it can get. And the end result is a real gem.
Keith Brown
RV-14A Builder - kit #136 (complete) and #770 (in process)
N314KC - First flight Mar 8, 2017, 24th in the air, >750 hrs
XP-400 Aero Sport Power, replaced with Lyc Thunderbolt 390
RV-6A sold
Sport Pilot (weight-shift control) - Airborne XT912
Dues paid 9/2021
Old 03-13-2018, 09:25 PM
mikefox mikefox is offline
Default Congrats!
You?ll have fun while doing a great job and end up with a fantastic plane!
Remember, Red, hope is a good thing, maybe the best of things, and no good thing ever dies. I will be hoping that this letter finds you, and finds you well.
Old 03-13-2018, 10:28 PM
terrye terrye is offline
The original tappets on Lycoming and Continental were flat (actually slightly crowned) made of chilled cast iron that ran directly on the cam. The tappet operated the pushrod which in turn operated the rocker which opened the valve. Roller tappets have a small wheel or roller on a pin or axle that runs directly on the cam. The main advantage is lower wear, especially at startup.
Terry Edwards
RV-9A (Fuselage)
2021/2022 VAF Contribution Sent
Old 03-14-2018, 06:16 AM
Default Anything you would add to the order?
Thank you all for the support and finally revealing the mysteries of the roller tappet
Old 03-14-2018, 11:09 AM
PatrickN PatrickN is offline
Welcome to the RV-14 club! I also just started my build and was where you are only a few weeks ago.
RV-14 #140469
Empennage Kit: Complete
Fuselage Kit: Complete
Finishing Kit: Mostly Complete
FWF: In Progress
Old 03-14-2018, 11:52 AM
SabreFlyr SabreFlyr is offline
I find it interesting that Van?s has sold a little fewer than 500 -14/-14A kits in less than six years (correct me if I?m wrong) and more than 10% of them are flying. When you consider how many are more recent starts that could not reasonably be expected to be completed yet, that?s a pretty good completion rate. That is, at least compared to the overall completion rate of about 24-25% of original purchasers for most kits. My own kit bucks that positive trend, though, as I?m the second owner.
Good luck, Rich! Welcome to the club and bring us all of your questions. We?ll be more than happy to tell you that none of us ever had whatever problem you?re dealing with! 🤥
Ray Dosh
LJ45 driver
RV-14 #140212
Empennage completed
QB wings 95% done
QB fuse in progress
2021 DUES PAID
Marion, IN MZZ
Old 03-14-2018, 12:47 PM
dejavu dejavu is offline
You may consider adding:
Tank sealant: for the elevators' foam ribs; the 1 oz is sufficient.
Double side tape: for the rudder and elevators trailing edges. If you elect to use tank sealant, you may consider ordering additional sealant.
Additional 470 & 426 rivets: if you made rivet cards or other practice material. Their size would depend thickness of the material and the size holes you drilled.
Rivet tape:
Boelube:
Safety wire: if you don't have a local source.
-Tom
Old 03-14-2018, 01:20 PM
unfluencer
Welcome aboard, Rich! We've all been there....it's a journey and you don't even know what you don't know (but you'll learn). And it's worth it.
Welcome again!
b,d
Doug Reeves (your host)
  • Part time: Contract Pilot (PIC type in Embraer Phenom 300). Flying resume.
  • Part time: Phenom 300 (currently) and Gulfstream 450/550 (soon) Seat Support at CAE (KDFW).
