Old 03-07-2007, 05:27 PM
andrew phillips's Avatar
andrew phillips andrew phillips is offline
Default installing plexi lens on wing tip?
I can't seem to find any plans/instructions for cutting the plexiglass lens or on how to attach it to the fiberglass wingtip. If there is a plan out there could someone email it to me or fax me 613-836-8708 or post a picture.
Andrew Phillips
7A QB - working on everything
Old 03-07-2007, 06:03 PM
Rick_A's Avatar
Rick_A Rick_A is offline
Default The plans don't show much ...
I don't have them handy, but I remember that they didn't really help a lot. Basically, cut the lens in half and then keep cutting until they fit - which is easier said than done. I was not able to get all the edges perfectly flush, so I'm fairing the tips to match the lense!
The plans show using just 2 screws to hold them in place - 1 in the upper inside corner and 1 in the lower inside corner. I put in more than that.
Rick Aronow,
A&P
Flying 7A Slider;
RV-12 SOLD
Highland Village,TX
Old 03-07-2007, 06:21 PM
Ironflight's Avatar
VAF Moderator / Line Boy
Default It's Art!
Buildign these planes is part engineering, part art....this part is art! Do it like Rick says - cut until they fit. I used just two screws, and they work fine.
Paul
Paul F. Dye
RV-8 - N188PD - "Valkyrie"
RV-3B - N13PL - "Tsamsiyu"
Dayton Valley Airpark (A34)
http://Ironflight.com
Old 03-07-2007, 06:59 PM
joeboisselle joeboisselle is offline
I found on my lenses there were light scribe marks on the outer edges, I just cut to these lines and it fit great. I see vans uses two screws on their aircraft, but I used 6.
Joe Boisselle
2010 RV-4
1941 Luscombe 8C
Old 03-09-2007, 11:58 AM
Davepar's Avatar
Davepar Davepar is offline
I found my lens instructions in the bag with the hardware. As mentioned above, they aren't very helpful.
Dave Parsons, Seattle, WA, RV-7A, sold
www.dualrudder.com/rv7 - building blog
RunwayFinder.com - airport info, online charts, live METARs, TFRs, etc.
Old 03-09-2007, 01:44 PM
rv8ch's Avatar
rv8ch rv8ch is offline
Default Use a big honkin' file
I found that my "*******" file works perfectly on this lens and I was able to get it to fit really nicely. Just take care not to scratch the lens.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 03-09-2007, 08:05 PM
Default Thanks for all the input
I cut the lenses with a grinding wheel on a dremel then finished trimmed them on a stationary belt sander. it took about 10 mins to do both and they look great! I still need to drill the holes for the screws and I am done!
