04-01-2018, 10:53 AM
showplanes cowl
The showplaces cowl actually has an inner fairing to smooth the flow around the nose gear...
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
04-01-2018, 11:19 AM
Originally Posted by az_gila
Can you give us pictures of this?
Gil, Greg is speaking of something like the standard exit radius on an -8. You've seen the idea adapted to other models.
The -8 has an exit ramp inset into the belly, so the inset has sidewalls. The stock ramp is aluminum. A stainless overlay for a 10 could be curled at the cowl end, very much like the ramp in the foreground (here upside down on the bench), a one piece SS panel with integral sidewalls for an -8.
Dan Horton
RV-8 SS
Barrett IO-390
04-01-2018, 12:09 PM
Thanks, but I was wondering about the work fitting around the -10 nose gear, which is different from the -6A I'm familiar with. I'm also guessing that the lower cowling "bar" referred to was for the alternate screw (not hinge) mounting, but it wasn't quite specific.
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
04-01-2018, 12:45 PM
I'd bet it was for the bracket that ties the cowl to the bottom of the fuselage. None of the other models (except maybe the -14) have that.
There's a lot to work around down there on the -10.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
04-01-2018, 01:17 PM
But, isn't that the U-620 and U-621 stuff on my -6A? Plans sheet 61.
Gil Alexander
04-01-2018, 01:46 PM
I removed the heater cuff off of the right side. I have never missed it.
The scat from the left side connects to the SS diverter during winter and dumps overboard in the summer. That alone solves most of the problem. When it is in use it goes into a Y in the tunnel to provide heat fore and aft and it is plenty. In the summer I also use exhaust tip extenders since I have an A/C duct.
The fresh air that used to supply the right side cuff now goes direct to the SS firewall diverter and from there straight into the tunnel to ventilate it with cool fresh air. . In winter I have to close the valve in cruise because it gets cold to the touch. With this controllable setup, my tunnel and fuel plumbing stay ?room temperature? year round.
Myron Nelson
Mesa, AZ
RV-10 N24EV
KITPLANES Contributing Editor
04-01-2018, 03:32 PM
Maybe I'm ignorant of how the -A models work. Wouldn't be the first time. ;-)
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
