03-12-2018, 12:21 PM
Originally Posted by az_gila
If I read your blog pictures correctly, the 1/16 Fibrerfrax is sandwiched between the two skins (SS and original belly aluminum) by the same rivets that attach the skins to the fuselage ribs.
Wouldn't having this layer of Fiberfrax in the assembly screw up the structural integrity of the skin to rib riveted joint?
I don't know how either Mike or Kyle assembled theirs, but I would not use the rivets in the plans to ensure no compromise to structural integrity. I would off set rivets lines dedicated to the stainless plate.
03-12-2018, 01:10 PM
That's what I did. The primary structure is per plans. The pop rivets for the overlay are just there to attach the stainless sheet.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
03-12-2018, 03:06 PM
My belly shield does, in fact, use the rivets that attach the ribs to the bottom skin. I used rivets slightly longer than the ones called for by the plans, in order to get the proper diameter/height on the shop head.
Keep in mind, that 1) my belly shield is not the full length of the bottom skin, only the first 18 inches or so, 2) the Fiberfrax crushes a little at the point of attachment, leaving very little thickness at the rivet lines and 3) the SS sheet would add a bit of tensile capacity to the bottom skin.
It would probably have been better to use separate/extra rivets to secure the SS sheet/FF to the belly (I thought of that for my firewall), but, for my small belly shield, I didn't do it that way.
03-12-2018, 07:08 PM
Originally Posted by DanH
Do this ^^^^^
Dan,
Do you have any pictures of what that looks like?
Jeff
Rudder - Complete
Horizontal Stabilizer - Complete
Vertical Stabilizer - Complete
Elevators - Complete
Cabin Cover - Complete (wheewww!)
FWF - Complete
EFII 32 - In Progress
Dues Paid Through 2020
03-12-2018, 09:19 PM
Originally Posted by jeffwhip
Dan,
Jeff
Here you go (I think)...
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
03-17-2018, 04:33 PM
Thanks! That's what I'm looking for.
Rudder - Complete
FWF - Complete
03-17-2018, 04:53 PM
If it was me, I'd want to be sure the underlying skin was carefully prepared and corrosion proofed before riveting a plate on. Once you install it inspection will become impossible, and there is a good chances of moisture getting in between the 2 skins and with the dissimilar metals it could be a problem down the road. It would be more work but maybe worthwhile if you're building to use screw/nutplates to intall the sandwich.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
03-17-2018, 05:00 PM
Unless you start your -10 fuselage with this in mind, retrofitting nutplates under the floorboards will be a bear. That said, yes, do put a coat of epoxy or zinc chromate on the aluminum to protect it.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
03-18-2018, 08:46 AM
Another one
Dan,
Jeff
If I remember used 0.005" SS
Weasel
RV-4 715hr Sold
RV-10 "School Bus" -   +1600hr counting
Fisher Classic Cassler Power VW sold
RV-10 N7631T 820hr Sold
RV-8 700+hrs
Carbon Cub 200 hr Sold
One-Off Super Cub 100 hr
SERFI AWARDS
http://weaselrv10.blogspot.com/
03-18-2018, 12:27 PM
Stupid question, what's the purpose here?
I can only think it is to insulate from the heat of the exhaust.
Matt
CFI / RV-10
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
