Old 03-10-2018, 03:10 PM
RicoB RicoB is offline
Exclamation O-320 airbox opening size
Could anyone tell me what is the smallest size for the airbox opening would be for a O-320. I am trying to decide either to put the seal on the inner walls of the airbox or the outside like the book shows. But putting on the inside will def make the intake lil smaller..
thanks for all of the inputs
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
https://www.imdb.com/name/nm3018529
Old 03-10-2018, 03:13 PM
YellowJacket RV9 YellowJacket RV9 is offline
Is there a specific reason you would want to deviate from the plans and do it that way? Mine is per plans and works fine.
Chris
Chris Johnson
RV-9A - Done(ish) 4/5/16! Flying 4/7/16
Old 03-10-2018, 03:21 PM
Honestly i think the way the book says its fine but my partner has a preference of doing the the seals on the inner walls of the airbox. so i am doing my research and there isn't any problems i don't mind doing that way. My concern is ending up with a small opening. But what is too small?
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
Old 03-11-2018, 01:03 PM
No one has an idea on this?
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
Old 03-12-2018, 06:11 AM
The general consensus is to avoid deviating from the plans as it relates to critical systems. The power plant is a critical system. Since power is a factor of fuel AND air, if you voluntarily give up airflow you are giving away power.
Old 03-12-2018, 11:44 AM
Thank you for the reply. I agree with that myself .
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
