Old 03-10-2018, 09:05 AM
TShort TShort is offline
Default pull up resistor
I am starting to connect all the devices to the G3X system.
Can someone post a picture of exactly how you connect / wire up a pull up resistor for the active low inputs on the GEA 24?
I see how it connects on the wiring diagrams, but am curious how you actually connect it.
Google has been no help...
Thanks in advance.
Thomas
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
Old 03-11-2018, 09:09 AM
n82rb's Avatar
n82rb n82rb is offline
i solder a length of wire to both ends of the resistor, put the whole thing in heat shrink and put one wire to the pull up voltage bus and the other in with the wire to be pulled up at its terminal end.
bob burns
RV-4 N82B
Old 03-11-2018, 11:16 AM
wjb's Avatar
wjb wjb is offline
Looking at the GEA-24 specs, the inputs can be configured active-high or active-low; they don't seem to require an external pull up. from the G3X install manual:
23.5.9 Discrete Inputs
The GEA 24 has 4 configurable discrete inputs that can be used as either Active High or Active Low. These inputs are configured by the GDU (refer to Section 31.4.18 for GDU 37X systems and to Section 32.4.25 for GDU 45X/46X systems).
When configured as Active Low, the inputs conform to the following specification:
Active: Vin < 3.5 VDC, or Rin < 375 Ω
Inactive: Vin > 8 VDC, or Rin > 100 kΩ
When configured as Active High the inputs conform to the following specification:
Active: Vin > 8 VDC, or Rin > 100 kΩ
Inactive: Vin < 3.5 VDC, or Rin < 375 Ω
For the active-low case, a switch closure to ground will satisfy the conditions; no external pull-up is needed.
If you want to do a pull-up; Bob's instructions are correct.
Bill Bencze
Old 03-11-2018, 11:26 AM
Mike S's Avatar
Mike S Mike S is online now
Senior Curmudgeon
Sorry, no photos of my installation, but I used a screw terminal strip like this one
I installed ring terminals on the wiring to the EIS, and just turned a loop in the resistor wire to mount under the screws.
I was able to install all resistors on the strip, and all wiring to keep things neat.
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
