Go Back   VAF Forums > Model Specific > RV-14
Old 03-09-2018, 02:23 PM
Eztroller Eztroller is offline
Default HS Inspar rib to front spar-spacing
I am not happy with the spacing on this particular part. Trying to figure out what is causing it and am having a hard time.... looking through several books and have not been able to find the answer. Can someone point me in the correct direction.
https://photos.app.goo.gl/p2mJNMPj9K4f3Jrg2
Old 03-09-2018, 04:57 PM
Jake14 Jake14 is offline
My understanding is that slight gaps between rivets are not a big deal, but If after riveting you can get any feeler gauge to touch the rivet shank it is cause for rejection.
When using a squeezer, I had good luck putting a thin faucet washer or similar on the shop side of the rivet, so that when setting the rivet the washer squeezes the work together and effectively eliminates any gaps..
RV-14A flying 520 hrs
Old 03-09-2018, 08:07 PM
MED MED is offline
Buy some small diameter tubing. Then, by cutting short pieces you can have washers of any required length.
MED
140236
N435MD
Miss March 2020
Old 03-10-2018, 06:58 AM
mturnerb mturnerb is offline
I use this tubing to cut "custom" washers - works very nicely except when I sweep the shop they're everywhere...
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Turner Billingsley
RV-14A built/sold N14VB
RV-12iS in progress as of October 2020
Old 03-11-2018, 08:01 PM
coffeeguy coffeeguy is offline
What size did you use? I bought some vinyl tubing at my local Ace hardware, but it seems a little stiff. Tried a few different sizes too.
Jeff
Jeff Dingbaum
RV-14A empennage, wings, fuselage, finish
Cherokee 180
Old 03-11-2018, 08:20 PM
rjcthree's Avatar
rjcthree rjcthree is offline
Default Build on...
I rememeber getting a lecture from the support desk on an “issue” similar to the situation you’re asking about....I got told to put away my micrometer and feeler guages unless it was spar or engine related and build on. I blew it up and posted it it on the wall. With an BSME it was almost like blasphemy, but now almost through phase one...build on. ( I’m not saying being stupid or careless is ok, but now having been inside a Cherokee and a Skyhawk...yeah, I’ll take my workmanship over factory any day!)
Rick
RV-9A N183RC/90432: tip-up, O320H2, Ellison, Dynon D180, CPi2, Sen GA, at KLPR
RV-8 83718, wing kit, tanks done, with a four year plus plan - on hold due to home move
2011-2021 VAF contributor
Old 03-11-2018, 08:36 PM
Thanks for the feedback. I think im being too picky, but dont want to miss something important. I will try the faucet washers and move along. Much apppreciated!
Old 03-11-2018, 10:28 PM
Mudfly Mudfly is offline
If you use faucet washers, make sure they are the soft rubber type. Some are are more firm and won't give the results you are looking for. My supply is running low, and I'm having trouble finding the soft type. I think I'll try the tubing suggested by mturnerb above.
Shawn Edwards
RV-14A (140174)
www.myrv14build.blogspot.com
2021 VAF Donation
Old 03-11-2018, 11:21 PM
cczarnik cczarnik is offline
Silicone model airplane fuel line works great for me on 3/32. For ⅛ I use rubber drip irrigation line from the big box. Had both lying around.
Chuck
7a emp complete, wings underway
VAF Dues paid - 2018
Old 03-12-2018, 12:45 AM
CAVU Mark's Avatar
CAVU Mark CAVU Mark is offline
Default One rivet every 2 seconds
The women who built B-24s would set a rivet every 2 seconds, or so I'm told by the guys who used to work with them.
Mark
RV-3 sold - and I really miss it.
Stearman - N2S-5 completed/flying
L3 building for San Diego Air and Space Museum
Misc. others... F4F, F4U, HUP WACO YKS-7, JN4. TBF
