Old 03-06-2018, 05:24 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Default CS Conversion hardware
I'm converting my O-320-C2B to constant speed and I need the special front fitting and oil line. Where can I source these?
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 03-06-2018, 06:24 AM
Scremm's Avatar
Scremm Scremm is offline
http://www.airpowerinc.com Search for 75167, I believe this is the oil line you are looking for. They probably have the steel front fitting as well.
Claudio Scremin
N221Z RV8A Maine 600+ hrs
Old 03-06-2018, 06:40 AM
mike newall's Avatar
mike newall mike newall is offline
And take a deep breath before you open the page
"I add a little excitement, a little spice to your lives, and all you do is complain!" - Q
Donated in 2020
Old 03-06-2018, 09:52 AM
BruceMe's Avatar
It's just a stainless tube right? so I can fabricate one in aluminum, send it to a tubing shop to get stainless and get one for like... $20 right?
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 03-06-2018, 10:03 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Try talking to Tom at TS Flightlines?
Support a site advertiser.......
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 03-06-2018, 10:10 AM
pazmanyflyer's Avatar
pazmanyflyer pazmanyflyer is offline
Dowload Lycomings Service Instruction No. 1435 pdf publication from here https://www.lycoming.com/content/ser...uction-no-1435 It will give you the part numbers and alt hose info your looking for. For sourcing the best prices have been in favor to Air Power previously linked. There may be someone that switched out so look in the standard classified locations.
Carlos in Arizona
EAA Chapter 538 www.chapters.eaa.org/eaa538
Wittman Tailwind W8 N53CH (built & sold)
Pazmany PL-1 N2029 (bought & sold)
RV7 - N537TC (reserved & building)
Emp, Wings & Fuse done - working on FWF
"The air is an extremely dangerous, jealous and exacting mistress. Once under the spell most lovers are faithful to the end, which is not always old age." - Winston Churchill
