  #21
Old 04-16-2018, 07:26 AM
raabs raabs is offline
I had the discussion with P-Mag folks about the "three more weeks" for the past year+.
However I think they may be ready this time. I believe this is the first time they have been assembling many units to begin shipping. Proof is in the pudding and we'll see.
Rob Kelly
RV-10 Under Construction
Old 04-16-2018, 07:33 AM
Carl Froehlich's Avatar
Carl Froehlich Carl Froehlich is offline
Default Six cylinder pMag here at last?
I?ll let you know. I got a note from Brad that a few of us that have been pinging him for years will have our sets shipped this month.
I had superb service from his 4 cylinder pMags for over 800 hours (RV-8A) so have been nursing the orginal Slick mags on the RV-10 IO-540 waiting for the 200 series pMags. They are at the 500 hour point next month (conditional inspection month) so I?m hopeful to just replace them with pMags.
Carl
Old 04-16-2018, 07:58 AM
Mike S's Avatar
Mike S Mike S is offline
Senior Curmudgeon
Originally Posted by Aviator View Post
Yes, at S&F he had a display model of the 6cyl Pmag and will be ready in a few weeks.
Originally Posted by TShort View Post
There was a display model at OSH last summer too ....
Originally Posted by rocketman1988 View Post
The 6 cylinder Pmag appears to be made of Unobtanium.
It's been "a few weeks" for quite some time...
Yep -----remember it well. OSH 2011 it was. They told me they would be shipping before Christmas.
Breath holding not advised
Mike Starkey
VAF 909
Rv-10, N210LM.
Flying as of 12/4/2010
Phase 1 done, 2/4/2011
Old 04-16-2018, 09:01 AM
Toobuilder's Avatar
Indeed. The endless time on the waiting list for the P200 finally drove me to SDS' CPI system.
...And boy am I glad that happened!
Michael Robinson
______________
Harmon Rocket II -SDS EFI
RV-8 - SDS CPI
1940 Taylorcraft BL-65
1984 L39C
Old 04-16-2018, 09:13 AM
rocketman1988 rocketman1988 is offline
Default and...
The endless time on the waiting list for the P200 finally drove me to the FLYEFII system.
Bob
Aerospace Engineer '88
RV-10
Structure - 90% Done
Cabin Top - Aaarrghhh...
EFII System 32 - Done
297 HP Barrett Hung
ShowPlanes Cowl with Skybolts Fitted - Beautiful
Wiring...
Dues+ Paid 2019,...Thanks DR+
Old 05-13-2018, 07:52 AM
Ivan Kristensen's Avatar
Ivan Kristensen Ivan Kristensen is offline
Default Surefly EI pirep..
Originally Posted by kkmarshall View Post
Have 6 hrs on the new ignition including almost 5 hrs of that being a cross country and have been well pleased. I am very impressed by ease of install and timing. Reliability,time will tell.
Now that you have had a chance to build time on your new Surefly EI could you give us an updated flight report?
I have recently replaced my LH Slick Impulse Mag with a Surefly EI but have very little time on it. I am running a Light Speed Plasma III on the top plugs and now the Surefly EI on the bottom plugs.
I did notice on my first run-up and "Mag check" that the Surefly showed a significantly higher RPM drop as well as increase in EGT's compared with the Light Speed EI. I am wondering if you or anyone else have seen the same thing?
What is interesting is that in cruise flight at 8500Ft. there is very little difference in the way these two EI's affect EGT, CHT or LOP operations.
I would be very interested to hear from pilots with similar set-ups. Thx.
Ivan Kristensen
Guelph, ON. Canada
RV-10 (C-GMDV) 1355hrs.
Dual GRT 8.4" HXr EFIS, VP-200, TT A/P, Avidyne IFD440, uAvionixX ADS-B out, Sky Radar WX and Traffic, Dual EI's (one Lightspeed & one SDS CPI)
RV-14A under construction.
Link to my build site:
https://ivankristensen.smugmug.com/B...ENTAL-aircraft
Old 05-13-2018, 07:56 AM
Mike S's Avatar
Senior Curmudgeon
Timing, suspect I.
Or more correctly stated, advance curve.
Mike Starkey
VAF 909
Rv-10, N210LM.
Old 05-13-2018, 08:21 AM
kkmarshall kkmarshall is offline
Still very happy with it,hot or cold starts are quicker. I think it has a similar "mag drop" as a conventional mag b/c the timing is not advanced beyond 25 degrees at Runup RPM. Glad I did it and got rid of the problematic impulse coupler (on 540's anyway)
Keith
329DR RV10-bought flying
Continually upgrading/tweaking
Old 05-13-2018, 08:27 AM
Thanks for your replay! I also lost the RPM readout from the Surefly, Jason is working on a fix for that now. I am using a GRT EIS.
Ivan Kristensen
Guelph, ON. Canada
Old 05-13-2018, 10:51 AM
Carl
Any update on the pmag 200 for 6 cyl? Any in the wild yet?
Rob Kelly
