Originally Posted by Charles in SC
Thanks everybody for their input! The local paint store near me also suggested the SPI brand. Has anyone here ever accidentally used this and had the temp go below the 65 degrees called for in their brochure? If so what did you have to do to correct it ?
Spraying epoxy primer below 65 degrees may produce adhesion problems, so the fix would be stripping and repaint. But this would be the same with any epoxy primer not just SPI. It is possible to get good adhesion at low temperatures just not a guarantee. Call Barry at SPI he is the expert and may bve a bike to suggest a work around. But, I will expect that low temps and any epoxy primer is going to be an issue.
