Old 02-26-2018, 07:50 AM
BruceMe's Avatar
BruceMe BruceMe is offline
Default Shorter oil tube and level checker
Does anyone have the part numbers or information on making converting a shorter dip-stick and oil filler tube on an O-320?
Bruce Meacham
Building RV-4A 18ZM
Built/Own RV-4 254MM
First RV RV-3 3456B
VAF annual donation on autopay
Old 02-26-2018, 05:32 PM
I shortened mine long ago.
I simply figured out how much I needed to shorten it, cut that much out of the tube, and used a plumbing aisle PVC coupling (maybe CPVC?) to splice it back together. I used proseal to seal the thing and 3 internally wrenching set screws on each end as a secondary holding mechanism. (The proseal and screws came after the first time I assembled it and the PVC glue joints failed).
Then I painted it Lycoming grey.
For the dipstick, you can drive out the roll pin, pull the rod from the cap, and then drill a new hole for the roll pin at the appropriate distance from the first hole and reassemble with a new roll pin after shortening the upper end of the rod.
On mine, I didn't shorten it, I just used a pipe cutter to cut new marks for oil levels. I calibrated those marks one quart at a time as I filled the crankcase.
Hope this helps.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-01-2018, 10:27 AM
BruceMe's Avatar
Beautiful, thank you
Bruce Meacham
Building RV-4A 18ZM
First RV RV-3 3456B
Old 03-01-2018, 10:31 AM
Raymo's Avatar
Raymo Raymo is offline
I have a short tube (~6") available for $20+shipping, if it's not too short. These are typically installed on 540s.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
