Old 03-05-2007, 01:51 PM
JVolkober JVolkober is offline
Question Dynan Pitot Tube and AOA
I am considering a Dynon combination pitot tube and AOA source. The unit requires a second run of aluminum tubing for the AOA sensor. Suggestions on how to run the second tube? I have areading riveted the wing skeleton together.
John
Old 03-05-2007, 03:43 PM
ddddsp ddddsp is offline
To run another line of tubing out to the pitot is no big issue........you are not running aluminum tubing I hope. Tygon or something like Safeair1 sells can be fed thru existing snap bushings in your wings or the conduit runs. Some guys will even silicone it into the J channel stiffener along the wing.
Dean 40449
Old 03-05-2007, 06:11 PM
briand's Avatar
briand briand is offline
I HAD the safeair kit and would recommend buying the kits from them, if you want the Dynon AOA tube. They include everything AND show you how to do it. Price is fair.
BBBBBUUUUUTTTTT, what I really would recommend is going with the GRT setup instead. Hey just look at my location, OR ASK A GRT OWNER if you want to know why. I believe in supporting local bizznass'z and GRT's get kick-a@$ reviews.
Old 03-07-2007, 01:39 PM
Question Tygon or aluminum tubing
What is the downside, if any, of using tygon tubing instead of aluminum for the run from the pitot AOA tubes? My sailplane is 15 years old, uses only tygon for the pitot static system and has not problems. Seems tygon should work fine in an RV.
