Old 02-17-2018, 12:49 PM
Tim_AZ's Avatar
Tim_AZ Tim_AZ is offline
Default Need some guidence in regards to riveting 3 parts together
I'm working on the airfoil practice kit and I'm having an issue riveting the spar/rib/reinforcement plate assembly together. Each time I try I end up with a small gap between the rib and the spar. I tried getting a clamp in there but I don't have one small enough to engage and still get the bucking bar in place. What is the trick to this? Thanks.
Old 02-17-2018, 01:24 PM
rvbuilder2002's Avatar
Often times when forming a shop head against thin material the localized strain induced against the thin material causes it to pucker sightly.
The material is usually still in contact around the perimeter of the hole but puckers out slightly further out.
This is totally acceptable from a structural strength standpoint, but just doesn't look as nice.
This is why best practice is to form the shop head on the thickest material but that is not an option when thinner material is on both side.
Bottom line is that as long as the parts are in contact around the perimeter of the rivet it is a good riveted connection
Scott McDaniels
Hubbard, Oregon
Old 02-17-2018, 01:58 PM
PilotjohnS PilotjohnS is offline
Default Rc fuel tubing
I use a piece of rc fuel tubing to push the parts together as the shop head starts to form. This keeps the parts from seperating on inital forming. But I tend to pull the tubing off for the last hits otherwise the shop head tends to come out crooked. Yesterday, I had to use this trick on the bottom skin rivets for the skin to rear spar to rib flange, where the spar is sandwiched between the skin and the rib flange
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 5% in work
Firewall Forward 5% in work
www.pilotjohnsrv9.blogspot.com
Last edited by PilotjohnS : 02-18-2018 at 08:45 AM. Reason: Spelling added wing details
Old 02-17-2018, 04:20 PM
wirejock's Avatar
wirejock wirejock is offline
Default Windshield washer hose
Originally Posted by PilotjohnS View Post
I use a piece of rc fuel tubing to push the parts together as the shop head startsto form. These keps the parts from seperating on inital forming. But i tend to pull the tubing off for the last hits otherwise the shop head tends to come out crooked
Beat me. Windshield washer hose also works if you can't find the clear stuff.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 02-17-2018, 05:57 PM
JonJay's Avatar
JonJay JonJay is offline
With practice you can learn to swell the rivet and use the squeezer or bucking bar next to the river and lightly squeeze or tap the skin then finish the set. It is really easy to ding a flange until you get the hang of it but it is quick and effective. Try it on your practice piece.
RV6 - Builder/Flying
Bucker Jungmann
RV1 - Proud Pilot.
Old 02-17-2018, 06:20 PM
I use a bit of neoprene or rubber fuel line with the -4 rivets. Haven't needed it for the -3 rivets.
Dave
RV-3B, skinning the fuselage
