Old 02-17-2018, 05:48 AM
Captain_John's Avatar
Default Brake caliper pin lubricant
So, I was wondering what you use on your calipers to ensure good movement of the caliper on the pins.
My A&P IA friend says anti-seize. That sounds reasonable.
I have read the Cleveland Technicians guide and there is NO MENTION of lubricating these parts at all.
What's your take?
CJ
The experiment works!
Old 02-17-2018, 06:05 AM
Electrogunner Electrogunner is offline
Default Lube
I just installed a set of matcos on a -10, and again nothing in the install docs mention it. I?ll stay tuned. But a little anti seize couldn?t hurt.
RV10 N620RV
IO540 C4B5
Whirlwind 375RV prop
Garmin G900X
First Flight 2/14/2019
scard's Avatar
scard scard is online now
What's your take?
CJ
dry moly lube
But general service history that I've seen seems to indicate it isn't really necessary.
Scott Card
CMW E-Lift
Old 02-17-2018, 06:38 AM
RV6_flyer's Avatar
What's your take?
CJ
For the past 20+ years and over 3,300 operating hours, I have used the brake manufacturers recommended lubrication. Nothing. I just clean them off and put them together.
Any liquid, paste, or grease will just collect brake dust and prevent movement.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 02-17-2018, 06:44 AM
Bob Martin's Avatar
Bob Martin Bob Martin is offline
My Take is I use lube.
Like Scott said, Dry Molly Lube...
or one of many "brake caliper greases" on the market at the auto parts store or Amazon. It is very similar to anti-seize. My thoughts are if you don't fly much or in nice enviroments and service (clean)your brakes annually, you might not need it. But if I have the assemblies off, which I do every year, I clean and re-lube very sparingly. Too much might attract unwanted debri to collect. You will not need much, if you buy a small tub, 1/2 pt. maybe, it will last two lifetimes. I have a small tub and I use a acid brush to apply it. After all, they do make the product, why not use it?
Bob Martin
RV-6, 0-360 Hartzell C/S, Tip up, 1200+TT
James extended cowl/plenum, induction, -8VS and Rudder. TSFlightline hoses. Oregon Aero leather seats.
D100-KMD150-660-TT ADI2- AS air/oil seperator. Vetterman exhaust with turndown tips.
Louisa, Virginia KLKU N94TB
Old 02-17-2018, 08:51 AM
DHeal DHeal is offline
I asked Matco's service rep and he said to just keep them clean and dry. In my experience, any form of lube is generally bad in that it attracts and holds dirt and grit leading to wear and sticking slider pins. I use silicone spray (dripped on, not sprayed) or dry graphite on my various aircraft and car slider pins.
David Heal - Windsor, CA (near Santa Rosa)
EAA #23982 (circa 1965) - EAA Technical Counselor and Flight Advisor; CFI - A&I
RV-12 E-LSA #120496 (SV w/ AP and ADS-B 2020) - N124DH flying since March 2014 - 940+ hours (as of September 2020)!
VAF donation through June 2021.
Old 02-17-2018, 11:50 AM
9GT's Avatar
9GT 9GT is offline
Dry lubricant, if any, period. Unlike automotive pins which are weatherproofed in accordion style sleeves, ours are exposed and will collect dust and dirt like a magnet!
David C.
Howell, MI
Old 02-17-2018, 02:12 PM
ArlingtonRV ArlingtonRV is offline
I use the CRC Dry Graphite Lube spray from Aircraft Spruce (ACS P/N 09-02427).
Steve Rush
Arlington, WA
ArlingtonRV on YouTube
RV-8 (Bought Flying)
Glasair Sportsman (Sold)
RV-8 Tail, QB Fuselage (Sold)
RV-4 (Bought Flying) (Sold)
RV-9 Tail
RV-12 120018 Flying (Sold)
RV-7 Tail, Wings, Started Fuse (Sold)
Old 03-10-2018, 06:38 AM
Red Mtn flyer Red Mtn flyer is offline
Default moly powder or nothing
Polish them [and the inside bore] lightly and leave them -- or apply powdered moly lightly with a cloth [you don't leave much behind, or need much]. You are generating grit with your brake pad right there -- ANY liquid/ carrier will attract and hold the grit, which turns your parts into a grinding machine.
The moly will impregnate the surface pores, so you'll build up a lubricating surface - but the real key is keeping them clean and smooth.
Ben K.
A&P; RLSA - A,G,W/S Falco F-8L
50 yrs of flight and counting
Dues paid 2017 thru 2020
Old 03-10-2018, 07:07 AM
F1Boss's Avatar
F1Boss F1Boss is offline
Default Dry graphite
On the farm equipment, we use the dry lube so dirt does not collect as it would on greased parts. That product was also spec?d by Beech for the slide tubes on the landing gear in the 30s - I did not know that stuff was around that long.
Farm stores sell it in a spray too, with what smells like an acetone carrier that flashes off quickly.
Messy stuff tho!
Best,
Mark
"Not everyone needs a Rocket. Some folks, however, shouldn't live life without one.
You know who you are."
Budd Davisson, 1997
