  #81
Old 02-24-2018, 10:38 AM
John C's Avatar
John C John C is offline
I used the Magnaflux Spot Check. It was $80-90 from Zoro, free shipping, no tax. They said a week or two for shipping, but it came in 4 days from Texas to Kansas, UPS.
John Clark
Moundridge, KS
RV-9A 90512 N6699 Sold
RV-12 120323 N6699Z 410 hours
dues paid 2018
Old 02-24-2018, 01:36 PM
TomVal's Avatar
TomVal TomVal is offline
Thanks John.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 02-24-2018, 10:20 PM
RFSchaller RFSchaller is offline
I?m not going to bother with looking for racks, just install the fix. If you find cracks the solution is the fix, so what?s the point in inspecting if you just put in the mod?
Old 02-24-2018, 10:52 PM
KALEWIS's Avatar
KALEWIS KALEWIS is offline
You would need to stop drill any cracks ......
Airspeed, Altitude, or Brains...you need at least two
RV-12 #328
At 630 Hrs on the Hobbs
Old 02-26-2018, 09:08 PM
Oops, sorry, I meant that post to be on the HS spar crack mod thread. Senior moment, I guess!
Old 03-01-2018, 07:50 PM
funflying funflying is offline
Default Post #59
So sorry for some mis-information reference the clips for the turnbuckles. These clips are not in the SB18-02-02 parts. It was actually 2 cotter pins with also have an MS##### similar to the clips.
Bottom line....no clips so if you anticipate re-adjusting the turnbuckles order additional clips.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 03-01-2018, 08:59 PM
Mitch757 Mitch757 is offline
I got 2 clips and cotter pins with my kit.
Mitch Garner
RV12 flying year 3
Old 03-01-2018, 09:12 PM
Jim T Jim T is offline
Mitch Garner
RV12 flying year 3
Same for me.
RV-12 kit (sold)
2006 Rans S-6S Coyote (flying)
Old 03-01-2018, 10:04 PM
Slane Slane is offline
Mitch Garner
RV12 flying year 3
I had ordered the SB package earlier and picked it up today. Two cotter pins and nso cable clips. Vans is out of these clips and so they’re now on ‘back order’. Could be a long wait so I was advised to locate clips from another vendor.
On another SB note, is there something special about the aviation penetration dye that is lacking in more common penetration dye kits available at the auto parts store? What are people using and where have they purchased it?
Thanks for info.
Scott Lane
Hillsboro, OR
RV12 Completed & Flying 2013
#120043 N728SL
Old 03-02-2018, 07:12 AM
Skunkworks's Avatar
Skunkworks Skunkworks is offline
Post Jane is having major surgery SB 18-02-02 the elevator.
Jane is very fortunate in that she is rich with friends that want to help her out. This time it was major surgery SB 18-02-02 the elevator.
Dave, friend and A&P mechanic, came over with his specially built table just for the RV-12 fleet.
His table is already reserved for use for another RV-12 at Wings Field.
Certainly made the job a bit easier, just slide it under adjust height to match and we were all set.
Service Bulletin 18-02-02 to address any potential cracking in the horizontal stabilator front spar.
Did not find any cracking on Jane, however, performed the SB as a prevention measure.
Had to hold for 24 hrs due to finding one of the bearings would slip out of the flange with little pressure.
Put Loctite on it and checked the following day and we were good to go for Elevator installation.
Click on image to see Time Lapse video of the surgery.
RV-12 ELSA N470MB S/N 120470
Flying Since March 2013
1200 hours as of 05/30/2020:
VAF 2020 Donation Current
