VAF on Twitter:
@VansAirForceNet
Old 02-15-2018, 04:42 PM
DeltaRomeo's Avatar
DeltaRomeo DeltaRomeo is online now
unfluencer
Exclamation SB 18-02-02 Potential cracking in the horizontal stabilator front spar
Issued today:
RV-12. Before further flight.
http://www.vansaircraft.com/pdf/sb18-02-02.pdf
"Inspect stabilator front spar for cracks. If cracks are not present the aircraft may be returned to service until the next 100 hour or annual inspection, when this service bulletin should be performed before further flight. If cracks are found, complete this SB immediately. Kits under construction should perform this SB prior to stabilator attachment or first flight."
v/r,
dr
Doug Reeves (your host)
  • Available as Contract Pilot (ATP. PIC typed in G-V(450/550) and Phenom 300). Flying resume.
  • Part time: G450/550 and Phenom 300 seat support at CAE (KDFW).
Old 02-15-2018, 05:01 PM
moosepileit moosepileit is offline
Default RV-12
Model RV-12
RV-6, bought from builder.
O-320, slider, carb, mags, FP
Old 02-15-2018, 08:21 PM
MrSparkle MrSparkle is offline
Default Inspection for cracks
I assume that the only way to inspect the stabilator's front spar for cracks is to remove the stabilator and the hinge brackets. Agree/disagree?
Ian Heritch
RV-12 N417E
Old 02-15-2018, 09:21 PM
alexe alexe is offline
Agree. At that point you might as well do the fix rather than waiting to do it at the next conditional inspection. This is not going to be fun!
Alex
Alex Erdelyi
RV-9A Purchased
RV-12 Built and Sold
Paid through December, 2022
Old 02-15-2018, 09:26 PM
E. D. Eliot E. D. Eliot is offline
Default Want to comply!!
I do appreciate this SB and all of the work that the technical staff at Van's must have put into it. Would have liked to order tonight but can't because I'm not sure which new parts need to be ordered. I'll call tomorrow along with many of you.
Recommendation to Van's --- please add a short note that lists the parts need in order to comply. If Van's did that this time then I apologize profusely.
Thanks again for the SB.
Building finally
Old 02-15-2018, 11:08 PM
rgmwa rgmwa is offline
Ian Heritch
RV-12 N417E
That's if you can actually see any cracks. They would be very easy to miss judging by the photos in the SB. I wonder what prompted Vans to look there, although I guess it's an obvious potential trouble spot when you think about it. This won't be a fun job, but if you have to pull everything apart to check you might as well bite the bullet and do the fix at the same time.
RV-12LR 912ULS 120346
Old 02-15-2018, 11:33 PM
Harvey rv12 Harvey rv12 is online now
Vans SB?s usually have a ?synopsis? detailing what prompted the bulletin.
This SB doesn?t say much. Would be interesting to learn how this was discovered.
Tom O.
RV-12, bought flying
Hoskins Field, 44T
Olympia WA
the bitterness of poor quality
lingers long after the cheap
price is forgotten.
Old 02-16-2018, 07:21 AM
skydiverlv skydiverlv is offline
I like the 6hr labor estimate. That indicates how old and slow I am.
Larry Vandegrift
ULPower 260is
Old 02-16-2018, 08:25 AM
Piper J3's Avatar
Piper J3 Piper J3 is offline
I wonder if Van's will supply parts free-of-charge for this SB like they did for fuel tank and landing gear?
Jim Stricker - EAA #499867
PPL/ASEL 1970 - Sport Pilot since 2007
80 hrs Flying Aeronca Chief 11AC N86203
1130 hrs Flying 46 Piper J-3 Cub N6841H
Bought Flying RV-12 #120058 Oct 2015 with 48TT - Hobbs now 830
LSRM-A Certificate 2016 for RV-12 N633CM
Special Thanks... EJ Trucks - USN Crew Chief A-4 Skyhawk
MJ Stricker (Father - CFI) - USAAF 1st Lt. Captain B-17H
Old 02-16-2018, 09:16 AM
TomVal's Avatar
TomVal TomVal is offline
Since the stabilizer has to be pulled, if you haven't already done so, might as well complete SB 16-08-01 - Stabilizer Bearing Inspection.
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
