Go Back   VAF Forums > Model Specific > RV-9/9A
Old 02-12-2018, 12:07 PM
Surfdoc Surfdoc is offline
Default 9 Elevator leading edge spar to skin riveting
Just started the right elevator and keep scratching my head as to how to rivet the spar to the skin. There is an option for blind rivets on the bottom on the skin/spar but who is to say not the top? I can not for the life of me figure out how to get my hand in there to rivet that top section of skin to spar on the elevator. I really hope I explained this well...
Old 02-12-2018, 12:26 PM
bruceh's Avatar
bruceh bruceh is offline
You can bend back the skin quite a way (well over 90 degrees) to get in there with a small bucking bar.
Bruce Hill
RV-9A N5771H flown over 900 hours!
APRS Tracking for KJ6YRP and Flying Over the Hills Blog
2021 VAF donator
EAA Tech Counselor, Pre Buys, Build assistance - canopy/tanks/fiberglass/electrical/repairs
Old 02-12-2018, 12:37 PM
tyconnell's Avatar
tyconnell tyconnell is offline
We are in the exact same place, and bruceh's picture shows how to set it up. You will need to reach around / over the spar with a bucking bar and set it with a mushroom set. My tech counselor had to show me how to approach this over this last weekend. I had tried to backrivet it with miserable results.
Ty Connell
ty.connell@gmail.com
Donated 2021
Old 02-12-2018, 01:38 PM
airguy's Avatar
airguy airguy is offline
Yep, that's the way to do it - open it up enough that you can slip a small bar in there and hold it in place with your fingers. A tungsten bar helps, if you have one. If I remember correctly this is the point in my project, and the exact reason why, that I bought my tungsten bucking bar.
Garden City, TX VAF 2021 dues paid
N16GN flying 900 hrs and counting; IO360, SDS, WWRV200, Dynon HDX, IFD440, G5
Old 02-12-2018, 08:46 PM
tyconnell's Avatar
Default DOH!
Unrelated, I was reading ahead in the plans, and came across page 6-12 which demonstrates this.
Ty Connell
Donated 2021
Old 02-13-2018, 06:52 AM
eric.the.blonde eric.the.blonde is offline
I doctored a tungsten bar as shown with 1) Duct tape to prevent scratches, 2) 3 narrow 1/8" cork pads along the top to keep the bar square to the web/rivet (the spar flange is not 90 deg to the web), and 3) the square pads are spaced between dimples and help keep the bar square and prevent a shop head from being pounded too thin. The results were pretty good.
https://photos.app.goo.gl/jb6Bkj0usuqob1C53
Eric G.
Ann Arbor, MI
RV-9A under construction (wings, on order: QB fuse, IO-320, and prop)
President, EAA Chapter 333 Flying Stinkers
Old 02-13-2018, 01:07 PM
bruceh's Avatar
Yup, been there, done that!
Bruce Hill
2021 VAF donator
Old 02-15-2018, 11:32 PM
dr cooper dr cooper is offline
Default Elevator skin to spar
I don't like pulled rivets, so I used solid rivets top and bottom using a 3/4" x 2" flat steel bar, the length of the elevator.
I tried posting pictures before but I just can't get them to post. If you're interested to see my set-up, just email me. The letters: delta charlie mike sierra at xplornet.ca
I won't lay claim to the design because I borrowed the idea from someone else a long time ago.
The elevators look really good with the solid rivets!
Cliff Jones 9A
Pritchard, BC
Old 02-22-2018, 08:38 AM
Neal Trombley Neal Trombley is offline
I did a lousy job on my Right Elevator with the bucking...
starting the left hopefully with better results
I will use a RE that I purchased with a wing kit...
Neal Trombley
SW Florida
EAA 66
N517NC ( reserved)
Dues Paid
NOV 2016
July 2017
Dec 2017
