Go Back   VAF Forums > RV Firewall Forward Section > Electronic Ignition Systems
Old 02-09-2018, 12:54 PM
bob888 bob888 is offline
Default electronic ignition question
I have an Electroair ignition on one side, standard magneto on the other. I am getting misfire on the EI at lower manifold pressures = advanced timing. I also have high compression pistons (10:1). Has anyone with this combination (EI ignition and high compression) had problems like this?
Old 02-09-2018, 05:48 PM
Walt's Avatar
Walt Walt is offline
I doubt the higher compression has anything to do with your misfire.
I have an Electroair on one side with standard comp and have never had any problems.
Walt Aronow, DFW, TX (52F)
EXP Aircraft Services LLC
Old 02-10-2018, 05:26 AM
Bill.Peyton's Avatar
Bill.Peyton Bill.Peyton is offline
Bob,
I also have the electroaire I do not get any misfires at all. Do you have your data logs for the flight you can upload to Saavy and share? Do you have your plug wires separated with wire looms? Is it a specific cylinder that this occurs on, or just general misfire?
Bill Peyton
RV-10 - 1125 hrs
N37CP
First Flight Oct 2012
Aviation Partners, LLC
Old 02-10-2018, 07:25 AM
Omega232Devils's Avatar
Omega232Devils Omega232Devils is offline
Default Which version
Bob,
Which system do you have? The newer ElectroAir or older Jeff Rose system?
If the Jeff Rose, do a search and you will find the problems I had with the same system set up that you have and failure of Jeff Rose/ElectroAir system.
Dan
Dan Thompson
RV-6A - N426JM - 180hp / C.S. / dual PMags
NC26 - Long Island Airpark, NC
Old 02-10-2018, 08:46 AM
Default EI misfire
Thanks for your responses. I do have wire looms and the newer EI system with the 6 cylinder MTH. I have the timing wire passing through the firewall in the same bundle with the power wires for the ignition coils, which Electroair thinks may be a problem. Anybody else have these bundled together?
