Old 03-04-2007, 05:57 PM
beech29r beech29r is offline
Default 6A with a Warp Drive 4 blade?
I'm thinking of traveling to check out a flying 6A in Utah and would appreciate any info anyone might have on N30760, slider, 160hp, built in 2002 with a Warp Drive 4 blade prop.
I don't find any info on the site about builders using Warp Drive adjustable pitch props. Opinions? Other than that it looks like a nice 6A... from what I can tell by the pics.
New to the site, so hopefully this is the right place to post this.
Old 03-04-2007, 06:58 PM
Mel's Avatar
Mel Mel is offline
There have been several RVs in this area to try the warp drive, 2-blade, 3-blade, and 4-blade. No one could get any performance with any warp drive prop.
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 03-04-2007, 07:02 PM
I suggest calling or e-mailing Warp Drive.
http://www.warpdriveprops.com/
Their website indicates that they do sell props for Lycomings and Continentals, but you may want to touch base with them anyway.
That wasn't the case 5 years ago, because their hub couldn't handle the torque pulses from our low RPM, high torque, 4 cylinder engines.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-04-2007, 07:41 PM
airguy's Avatar
airguy airguy is offline
Wait a minute - they designed/used/sold a hub that couldn't be used with the most common engine outputs in the aviation world? What exactly was their target market?
Old 03-04-2007, 07:43 PM
Ultralights, Kitfoxes, and the like.
Kyle Boatright
Marietta, GA
2001 RV-6 N46KB
2019(?) RV-10
Old 03-04-2007, 08:28 PM
painless painless is offline
Seems to me that you could get rid of the warp drive and hang a more RV-proven prop on it.
As I recall, this airplane has been for sale for some time. Might be a bargaining chip for you. Have him knock down the asking price to cover the cost of a different prop.
Regards,
Jeff Orear
RV6A N782P
Peshtigo, WI
Old 03-05-2007, 07:16 AM
DanH's Avatar
DanH DanH is offline
Target market is 2-stroke Rotax and 912/914, UL and lightplane. The Warp is a smart choice in pusher applications because the solid carbon blade withstands FOD so well.
Dan Horton
RV-8 SS
Barrett IO-390
