soft line
Hello, Here is the way I paint soft lines. Take a roll of tape and pull out however long a line you need and then roll the tape like a cigerette and tape the tape to itself with the sticky on the outside... 2.5in tape should work ok. Basically you make a straw out of the tape... then you place the tube on the surface and move it around to whatever pattern you need and then either place another piece of tape above it... On it... and spray
...__
__/0
Above the tape is the spray pattern. The top is the tape... the middle line is the masking and the tube of tape and the bottom is the surface... sorry I dont have a pic.
Brian
Brian Wallis
(Exempt AND VAF dues paid 02 FEB 16)
Callsign: VOODOO sold RV3 to pay for ratings  !!!
AP/IA COM/Multi/IFR/350 type
Reason: spacing
