Bendix regulated fuel pressure?
I know the RSA5 takes input pressure and regulates it to a specific output pressure and flow rate to the flow divider for the injectors - but is that discharge pressure referenced to MAP as measured at the servo? Does it keep the same delta-P across the injectors at high altitude as it does on the ground?
