Old 02-04-2018, 06:37 AM
Burtonport Burtonport is offline
Default 13-02, Step 5, AEX TIE DOWN PREPERATION
Hello. The wing spar assembly plans state to drill and tap the AEX Tie Down on both ends. Why do we have to tap to top end? Thanks.
Regards,
Damien
Damien Graham
Watertown, NY
VAF dues paid until 7-20
Old 02-04-2018, 06:52 AM
rgmwa rgmwa is offline
I believe it was to facilitate hoisting the plane up if that was going to be a useful feature for some builders. There's a #30 hole in the top wing skin just above the tie-down point, but as far as I know, nearly all builders have just put a rivet in it. I tapped both ends of the AEX block, but in hindsight the top one wasn't necessary.
rgmwa
RV-12LR 912ULS
120346
Old 02-04-2018, 08:22 AM
Thanks for the reply. An I/A friend of mine also thought that it might be useful for a hoist.
Regards,
Damien
Damien Graham
Watertown, NY
Old 02-04-2018, 02:55 PM
Rob H Rob H is offline
I?ve heard this question asked before. There were several jokes such as gun mount, external drop tanks, etc.
For the record, I plugged the hole in the skin with a rivet and did not tap both ends.
RV12 - building
Empennage finished
Wings finished
iS Fuselage in progress
ULS Fuselage kit - SOLD
Farmer - corn & soybeans
Firefighter
Knoxville, IL
Old 02-07-2018, 09:50 PM
DaveWelch DaveWelch is offline
Default No harm...
I figured the top hole and mount might be useful later, so I tapped it per instructions and put a rivet in the upper skin above. It?s another minuscule weight savings and the threads are there if needed for a camera (or gun mount). One mistake I made was to use the first tap I found in my garage. Right size, wrong thread pitch. Lesson: read the directions, read them again, measure twice, cut once!
Dave
RV12 N951DZ
First Flight 9/23/16!
No paint yet. Working on a scheme with John Deere colors or accents.
Old 02-07-2018, 11:04 PM
rv9builder rv9builder is offline
I wonder how much weight the top tiedown(s) can support?
Mark
RV-12iS Fuselage
RV-9A Project: Sold
VAF donation made for 2020
Old 02-08-2018, 10:27 AM
Bob Y Bob Y is offline
So, if one did use the top tie-down for lifting, does anyone know what the sanctioned method is for covering the hole?
Old 02-08-2018, 11:41 AM
funflying funflying is offline
Mine has a rivet in the top skin to fill that unused hole.
Also there was mentioned using the top access for a holding device to hang the plane. I recall a prior thread from a group in Switzerland where an RV12 hung from a hangar ceiling with many other aircraft also hanging and many below. The post wrote about the limited space issues in their area.
Patrick Claar
Arvada, CO BJC
RV12, #401, Flying 2013, N612PC
RV6, 1996-2010 sold
Old 02-08-2018, 02:51 PM
One day when I have to give up flying, I'll donate my 12 to the Smithsonian. All they have to do is drill out 2 rivets and hang it up. Vans think of everything.
rgmwa
RV-12LR 912ULS
120346
Old 02-11-2018, 06:58 PM
RFSchaller RFSchaller is offline
Always looking for a tax dodge, Bob?!
