03-04-2007, 11:46 AM
Broken tap in tie down hole
Help! I just broke my tap in the tie down hole (QB wings). I tried drilling out the broken piece (so I could use an extractor) but the steel is so hard that my drill bits just do not penetrate. What the trick? Hopefully there is one.
Andrew Phillips
03-04-2007, 11:50 AM
How flat is the end of the break? Maybe one of those "screw out" tools for stripped screw heads ... although they might not bite in the hard steel either.
You could remove the tiedown and flip it over ... not sure how the bolt holes would line up then...
Thomas
Thomas Short
KUMP - Indianapolis, IN / KAEJ - Buena Vista, CO
RV-10 N410TS bought / flying
RV-8 wings / fuse in progress ... still
1948 Cessna 170 N3949V
03-04-2007, 12:11 PM
follow up
the way the tap broke is as jagged as can be! because the wings are QB they are essentially finished so taking out this piece will be a real nightmare. I was hoping someone would know of some kind of drill bit or technique that will allow me to drill it out.
Andrew Phillips
03-04-2007, 12:14 PM
You may need to find someone with a portable EDM machine. I used to work in a machine shop. We did lots of threading and broke a few taps. EDM will disolve the tap without damaging the work piece. When tapping aluminum, be sure the tap is sharp. I use plenty of WD-40 for lubricant and back the tap often to clean chips from the thread being made. If the tap tries to bind in the hole do not try to force it.
Bob Severns
Eugene, Oregon
RV-6
03-04-2007, 01:01 PM
Pliers?
Any chance of getting a pair of needle nose pliers in there to grab the "web" of the tap?
gil in Tucson
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
03-04-2007, 01:15 PM
Easy!
Step #1: STOP trying to drill it out. There is no way you're ever going to drill into the tap. I know someone will chime in and say they've done it and it's no big deal but ignore them....give it up
Step #2: Go to your local machine shop, ebay or wherever, beg, borrow, buy, steal a tap extractor. These are designed to fit into the flutes of the tap and will allow you to remove it NO PROBLEM
Step #3: Follow the instructions and be more careful next time
John Coloccia
www.ballofshame.com
Former builder, but still lurking 'cause you're a pretty cool bunch...
03-04-2007, 01:57 PM
Possibility
Would it be possible to drill out the entire bracket and replace? Just a thought.
Darwin N. Barrie
Chandler AZ
www.JDair.com
RV-7 N717EE-Flying (Sold)
RV-7 N717AZ Flying, in paint
EMS Bell 407,
Eurocopter 350 A-Star Driver
03-04-2007, 02:16 PM
Moderator/Tech Counselor
That happened to me, too. Just bite the bullet and pull the tank off and replace the tie down. Removing the tank is really no big deal.
Next time be sure to drill the hole out with the proper size drill and tap using an approve AL tapping oil. Don't risk any more damage by trying to "dig" the old one out. Chances are the hole will be buggered up and won't tap properly, anyway.
Tap your new one before installing so you get the feel of tapping it. That way you won't wreck the other one.
Roberta
Been there, done that!
Roberta Hegy
Built/Flew an RV-7A
Air Troy Estates, East Troy, WI
Ford Expedition and TRICE "Q"
Built Glen L "ZIP" Classic Outboard Runabout and Super Spartan Hydroplane
Glen L Torpedo
03-04-2007, 02:47 PM
Here is a tap extractor in 1/4". They sell 3/8" ones as well, but they don't have a pic for it.
http://www.toolsource.com/ost/produc...BV0MSPVBUJ9DC7
I have used them before with success. Give it a try.
 CJ
The experiment works!
03-04-2007, 03:58 PM
Tap extractor, tap extrator, tap extractor - easy fix. When you begin re-tapping use plenty of lube. Also, don't go more than 1/2 turn before you back up and clear the threads. Aluminum strain hardens very quickly when it is worked. When you try to tap without backing up and clearing, you're packing very hard material all along the cutting surface.
