Old 02-01-2018, 10:18 PM
N777ZE's Avatar
N777ZE N777ZE is offline
Default Avionics harnesses
Anyone have a person or shop they can recommend to make a Kx155 harness. Thanks!
Old 02-01-2018, 10:48 PM
mikerkba mikerkba is offline
Default Stein Air
Stein Air. They are an advertiser here.
Good technical advice. Fast availability by phone. No BS in the sales. And zero defects products.
651-460-6955
info@steinair.com
Bona fides: I've been an intermittent customer since 2006.
Mike Coster
BUILDER: N92MB RV7A (A/W 3/2009) - Sold
ADOPTED/reworked: N4032Q RV8A (8/2017)
Building: S-21 Outback/Titan, tail and cockpit mated (3/2020)
KELY/Ely, NV
Old 02-01-2018, 11:05 PM
Bavafa Bavafa is offline
Approach Faststack is another with great reputation.
Mehrdad
N825SM RV7A - IO360M1B - SOLD
N825MS RV14A - IO390 - Flying
Dues paid
Old 02-02-2018, 05:57 AM
Ed_Wischmeyer's Avatar
Ed_Wischmeyer Ed_Wischmeyer is offline
Their product is good for an initial installation of a multi-unit system. Not sure I'd recommend them for adding on one unit to an existing system, unless they sell cables that do not have the hub connector at the other end.
RV-9A at KSAV (Savannah, GA; dual G3X Touch with autopilot, GTN650, GTX330ES, GDL52 ADSB-In)
Previously RV-4, RV-8, RV-8A, AirCam, Cessna 175
ATP CFII PhD, so I have no excuses when I screw up
2020 dues slightly overpaid
Retired - "They used to pay me to be good, now I'm good for nothing."
Old 02-02-2018, 06:11 AM
BCP Boys's Avatar
BCP Boys BCP Boys is offline
Default Stein
There is a reason why Stein is so busy. If you want your harness done right call them.
Amir
RV-7
RV-10 - Sold
Supporting VAF since the first visit
Old 02-02-2018, 07:58 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
The hardest part of wiring the KX-155 is finding the molex pins. After that, it's actually pretty trivial, especially given that you're going to need to plug the other ends of the wires into various things yourself anyway.
Just a thought in case the usual suspects are too backed up...
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
Old 02-02-2018, 08:08 AM
RicoB RicoB is offline
I had my schematics done by stein air and I did the harness myself, best thing I ever done.
Rico Burgos
2018- RV9a at KWHP
1959- C-150 at KMOD
https://www.imdb.com/name/nm3018529
