10-09-2019, 10:08 AM
I'm struggling to think how to get my cylinders horizontal with my RV-10 Control Approach pedals. The cylinders mount to the rear of the pedals, so can't just pull them forward like I guess others are doing. Maybe I can pull them towards the firewall??? I'll have to check.
www.N1017H.com
Tim Huneycutt, Capt, NCANG
PC-12 Pilot
N1017H RV-10 Flying 2019
EAA #: 1106970
2020 VAF Dues Paid!
10-09-2019, 10:56 AM
Tim,
I have the Control Approach system as well, I un-bolted the bottom of the cylinder and lifted them to rest on the firewall. They stayed there long enough to bleed.
Kevin Lippert
RV-14A N1402 Flying 03-2020
Phase 1 Complete 07-12-2020
Build Log
Zenith 750 completed 2016 -
Sold
10-09-2019, 11:37 AM
Lifting master cylinders
I was wondering that very thing. Which way works best. Lifted forward or aft? Lines facing up or lines facing down?
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
10-09-2019, 04:43 PM
I disconnected the lower bolts and tipped them up. The way they attach to standard pedals, this put the banjo fittings facing upward.
10-10-2019, 07:12 AM
Kevin, good to hear, thanks for the feedback. I'll do mine at the end of the month.
www.N1017H.com
PC-12 Pilot
EAA #: 1106970
2020 VAF Dues Paid!
10-10-2019, 09:26 AM
I’ve got my brakes working fairly well but still wondering if they are good enough. The top of the pedals move about an inch and a half. The cylinders move between a quarter and half of an inch. Once engaged they seem firm and hold pressure well. Is that consistent with others with beringer brakes?
10-10-2019, 08:17 PM
Bleeding Beringer Brakes
Albeit on and RV9A, I've got about 1/4" to 1/2" travel with no tendency to ride the brakes. They've got 70 hours on them and I can't say I've noticed any appreciable sign of deterioration. I have not bled them since the initial installation.
I have the pressure reducing/anti lock valve backed off. I wonder if you may have that turned up at all.
Michael Brooks
RV 9A QB
Flying
10-11-2019, 05:29 AM
I'd say mine move around 3/4 - 1" at the top fully compressed. I think you have to rely on the "feel" to tell you how they are working: Mine have a definite firmness and a very distinct end-point which comes well before the travel limit (before the springs on cylinders fully compress), and are quite even side-to-side. I had the same sort of concerns as you do, until I had a small leak and noticed a "spongy" feel on one side - after fixing the leak/re-bleeding, the firm feel came back and I was more comfortable. Running engine while setting prop RPM, the brakes held and the airplane actually skidded a bit until the cable I tied down to tail got taut (that was very momentary FYI just to get prop set).
Now that I'm flying brakes just feel "right", don't think about it much. I do test the pedal feel as part of every "GUMPS" check before landing.
11-01-2019, 11:59 AM
So I used the pressure bleeder method and have the right brake done in about three minutes. However, the left brake is proving impossible. I can't get any movement of the fluid at all, even at 15 psi. I have the master cylinders horizontal and confirmed both are open. I have a parking break and confirmed it's open as well. Any ideas? I'm banging my head here. Literally. On the flap bracket every stinking time.
www.N1017H.com
PC-12 Pilot
EAA #: 1106970
2020 VAF Dues Paid!
11-01-2019, 12:02 PM
Sent you an email.
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
