Old 01-31-2018, 12:37 PM
bkervaski's Avatar
bkervaski bkervaski is offline
Default ELT Antenna *BENDING*
For those of you with ELT antennas mounted in the cabin (RV-14 for example) how are you getting those clean antenna arcs/bends so it doesn't beat on the canopy?
RV-14A #140376
N196 (Flying)
2019 Bronze Lindy
Old 01-31-2018, 02:48 PM
I made an aluminum mounting bracket with a 20-degree bend from horizontal. It angles the antenna inward so there's not contact with the canopy.
Doug
RV-9A "slider"
Tail number N427DK
Donation made for 2020
Old 01-31-2018, 06:50 PM
DennisRhodes DennisRhodes is offline
Stick the top 4 inches of the antenna in a piece of Tygon tubing and attach to the structure. Done.
DRRhodes
2020 VAF Supporter
RV9 N908DR
Old 02-04-2018, 03:42 PM
swisseagle's Avatar
swisseagle swisseagle is offline
Default stand off fixation
Hello
I made a stand off fixation post out of delrin (POM). At the top a cable tie holds the antenna:
1. Away from the canopy
2. Away from the roll over bar
3. In a slight bow to follow the canopy
Sorry, no pictures.
Dominik
RV-7A, TMX-IO-320, FM-150, Sensenich FP
Flying since 28. April 2016
