Old 01-30-2018, 12:46 AM
atalla atalla is offline
Default Left Elevator AKZO Priming
Hello all
if you have any pointers they would be greatly appreciated
Thank you in advance.
https://youtu.be/JqS-Pqcgkpc
Andrew Atalla
Red Seal Automotive Service Technician
Red Seal Heavy Duty Equipment Service Technician
Welder/Fabricator
Squamish BC CYSE
RV-7 Left Elevator in progress
Dues paid
Old 01-30-2018, 10:20 AM
fl-mike's Avatar
fl-mike fl-mike is offline
Couple things:
1. Keep the spray gun trigger pulled to keep air flowing in between full-pulls that trigger paint flow. The pressure regulator at the gun should be set with air flowing (it will start at a high (compressor setting) and drop off after a couple seconds to the target value). This is why you are blowing parts off the table. (That first puff is probably at 80psi.) i.e. set the regulator at the gun with the trigger pulled to flow air, but not paint. Always half trigger the gun for a couple seconds before triggering paint if you have paused. Keep the air flowing after you paint off the end of the part and re-trigger the paint as you come back in.
2. The cardboard under the mesh is going to rebound paint (and air blasts) onto your parts. It would work better if the mesh is open to the floor.
Man, pneumatic dimpling scares me. One slip and....
Good luck!
Mike W
Venice, FL
N164WM
Old 01-30-2018, 10:32 AM
sblack sblack is offline
I can't see your video (youtube is blocked at the office) but if you are blowing parts off the table I know of one solution. I got it off VAF and it has worked well for me. For painting small parts I make a 2 ft by 1ft frame of scrap 1" x 1/2" and I wire the parts in the frame with safety wire. That way you can prime them and paint them and move them around without having to touch them. Works great.
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 01-30-2018, 10:58 AM
Taltruda Taltruda is offline
Did the 30 minute setup time help with disolving the particulates that you were getting in the bottom of the cup?
Old 01-30-2018, 12:29 PM
Great idea!
No the chunks were still there...
ill ease up on the music for ya as well.
Yeah, kinda like Sex
One little slip & your in deep ****....
Andrew Atalla
Welder/Fabricator
Squamish BC CYSE
Dues paid
Old 01-30-2018, 02:02 PM
Haha! I'm blaming you for making me late this morning. .snooze button, check emails, saw your video, next thing I know I'm running out the door trying to make it on time! I like your videos, keep them coming!
