Old 01-29-2018, 07:20 AM
dmat dmat is offline
Default Help Converting Fadec back to Fuel Injection (NJ area)
Hi all,
Been in discussions with AFP in doing a conversion of my aerosance FADEC back to Fuel Injection. Unfortunately, due to timing and the need to crack open the accessory case (to change out a gear), I am starting to lean towards doing the swap closer to home.
From what I can tell, I have all the parts for the swap aside from a couple of replacement gaskets.
Anyone in the NJ/NY area who could help me in the swap?
Dan
RV6A: N6389-->N456RJ - Avionics Upgrade & Restoration COMPLETE & Flying
WTB RV4/8?- Looking for a 4 or 8 that needs some love and TLC. PM me if you have one!
Donations Paid- Thank you VAF!
Old 01-29-2018, 08:50 AM
TomVal's Avatar
TomVal TomVal is offline
Originally Posted by dmat View Post
Hi all,
Dan
Dan,
I did that identical conversion on my -8 about 8-9 years ago. I opted to install slick mags and was able to use the existing mag drive gears.
Regards,
Tom
Tom Valenzia
RV8 (Sold)
RV12 Jabiru 2200 Powered (Sold)
Dues contributor since 2007
Learn from the mistakes of others. You won't live long enough to make all of them yourself...Anonymous
Old 01-29-2018, 09:09 AM
What is odd is the original engine had slick mags on it. Looking at the aerosance FADEC conversion manual, it indicates that the accessory case needed to be opened for an aerosance gear. So I assumed it would required to be opened and the old (original) put back in. Anymore info would be greatly appreciated.
Dan
Old 01-29-2018, 09:57 AM
TomVal's Avatar
Dan
I have to admit...my memory is a bit foggy on this conversion. As I recall, the left mag drive gear was standard, the right mag drive gear had timing marks on it so that the halls sensor could read rotation for ignition. Other than that, the right drive gear was still usable as is for a slick mag install so there was no need to pull the accessory case.
Tom Valenzia
RV8 (Sold)
Old 01-29-2018, 11:57 AM
Yes, from what the manual said, the fadec gear had timing marks on it. I didn't know if that meant there was something different with the gear aside from the mark. Man, if I don't have to pull the accessory case, I will be a happy boy!
D
