Originally Posted by Scott Will
On my Andair valve, I used some stainless button head socket screws found at Home Depot's aviation isle (fastener section). They look pretty good and are a low profile. (sorry best one I have)
I like the looks for the Button head cap screws on the valve installation, I will probably do that when I get to mine.
Perfect example of a commercial product being better suited than a certified one.(for this application) The only thing I would do different is put a thin coated aluminum washer under the head.
NAS1149D0416J or NAS1149D0416K
Stainless Steel and Aluminum have a bad relationship, and always if something goes wrong its the Aluminum that suffers.
Its best to have a 2 cent washer go south years later than a portion of structure.
Most do not realize that corrosion is common around a fuel valve.
Chilled fuel going through it, warm cabin, and you have a very small amount of condensation on panel that the fuel valve is is mounted to. I have noticed corrosion on the floors (right around the valve area) of many certified aircraft after yanking the carpet out for routine inspections.
