Old 01-27-2018, 01:27 PM
Sleepy's Avatar
Sleepy Sleepy is online now
Default Alternator Pivot Bolt Orientation
I am helping a friend install a Plane Power 60A alternator on a Lycoming IO-360-M1B. As I was tightening the boss mount bracket, I noticed the pivot bolt will not clear the flywheel when inserting it from the front as shown in the installation drawing. It is close, but with the bracket bolts tight it just will not go.
It seems to me there should not be any reason why I cannot just reverse the direction of the pivot bolt and insert it from the back side of the alternator.
I am probably overthinking this, but am I missing something here? The reason I ask, is after about an hour of searching VAF and the web I cannot find a single diagram or post showing anything, but the bolt being inserted from the front side of the alternator.
Scott
Scott Price
aka "Sleepy"
RV-4 - N485AB Flying
RV-8 - N687SD Fuselage 1/2 Done
Old 01-27-2018, 01:45 PM
Mel's Avatar
Mel Mel is offline
There is absolutely no reason you can't insert the bolt from the rear!
RV-6 Flying since 1993 (sold)
<rvmel(at)icloud.com>
Old 01-27-2018, 08:52 PM
Rallylancer122 Rallylancer122 is online now
Is there something special about the M1B or your flywheel that makes it different from any other 360? If there isn't, I would be curious why this is necessary on my engine and not others.
DEM
Old 01-28-2018, 12:52 AM
AviatorJ AviatorJ is offline
That's what I did last week on a B&C setup. Good to know it won't fall out!
Justin
RV-10, N10JW
First Flight 2/14/2019
http://operationrv10.blogspot.com/
