Removing Aero Composite Prop
Well it seems my Aero Composite Prop hub decided to start spitting grease. There are no zerk fittings so I called the (ex) distributor, American Propeller, and it looks like I'll be sending it in for an overhaul.
Only problem is I've never pulled a prop so I'm guessing I cut the safety wire and loosen the bolts, then grab a handfull of prop and... I'll have a pan to catch any oil. Anything else?
~Marc
RV-10
N814RV
2020 Donation Made
