01-22-2018, 04:23 PM
Do I need two nav antennae?
I installed a cat whisker antenna on top of the VS for VOR/GS. I was talking about antenna placement with friend who is an electrical engineer and he said he installed both a cat whisker and an Archer wing tip antenna for each of his two nav radios so that he didn't have to split the signal.
Is signal loss with a splitter that significant that I should be thinking about two seperate antennae?
______________________
Randy P.
1st time builder
RV10 - QB wings and fuse. Working on cabin top
St. Albert, Alberta, Canada
Reserved:C-GRPY
01-22-2018, 04:26 PM
Short answer - no.
Carl
01-22-2018, 05:44 PM
You can use a splitter. That is standard practice.
Jesse Saint
01-22-2018, 05:46 PM
Well, it sort of depends. In the case of a Garmin SL-30 nav/com, there is an internal splitter that sends 1/2 of the received signal to the navy receiver and the other 1/2 to the loc-gs function.
Other radios have separate nav and gs antenna inputs. In that case, you need a splitter if you only have one vor antenna. Or if you have multiple nav/gs receivers.
Each time you go through a splitter, the signal gets cut in half (or 3db). Using one splitter is not a big deal. The gs/loc signal is used when "close" to the airport environment and the VOR transmitters put out a much stronger signal for distance reception.
Another factor in our favor is that our modern receivers are very sensitive and can receive fainter /weaker signals than receivers of yesterday.
Another factor in received signal strength is antenna design and placement, but that is a different subject.
Noel
RV-6A N6NF
tip-up
flying
01-22-2018, 06:36 PM
If you're splitting signal between two straight up nav radios, each gets 50%, but the glide slope tuner is a different frequency, so it's not using any of the energy from the nav signal. Should be only slight insertion loss for the splitter.
Only real downside to using a splitter would be, if you want full redundancy for IFR you'd need to duplicate the antennas.
01-22-2018, 09:11 PM
If you're splitting one signal to a separate VOR/LOC and GS antenna inputs, such as on a GNS430, you want to use a *diplexer*, not just a splitter.
http://www.aircraftspruce.com/catalo...clickkey=11684
2019 Dues paid!
01-23-2018, 06:26 AM
Many builders have had good results with the archer antenna, when installed properly. Here is a thread on the subject.
It sounds like it is too late for you though.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
01-23-2018, 06:49 AM
Originally Posted by RV7A Flyer
Exactly right; I got lazy when typing my answer earlier. And if you look to the right on that product page, you'll see variations on that theme, including models with 2 VOR outputs and 1 or 2 glide slope outputs.
01-23-2018, 06:54 AM
Do you NEED two Nav antennas? No. But IMHO if you can install two without much effort then yes. YMMV
Galin
CP-ASEL-AMEL-IR
FCC Radiotelephone (PG) with Radar Endorsement
2020 Donation made
www.PuertoRicoFlyer.com
01-23-2018, 07:01 AM
A diplexer combines or splits a signal based on frequency. A splitter splits all signal frequencies it can see. Use the right one....in your case a diplexer. But check the freqs and applications.
Ooops. Read this - all the above appears to be wrong wrt your question. http://www.vansairforce.com/communit...ad.php?t=26063
Its not a spitter or a diplexer. Triplexer? T joint and diplexer? Yikes. Stein has some good comments on the thread above.....
Mani
Busby MustangII (FoldingWing) Pending DAR.
Don't be a hater; I'm a cousin with thin wings!
N251Y (res)
