01-21-2018, 10:42 PM
Dream RV-7A
I am in the process of getting ready to build an RV-7. I have searched for hours and hours for a consolidated source, but I could not find one. YMMV. I see a lot of new products on the market since I got my -10, and am hoping for some good input. If you could copy the below list and just add your suggestions, it would be greatly appreciated. The plane will have a slider and the engine will be a 180hp IO360 Lycoming.
Electronic Ignition  SDS, EFII, etc)
Vertical or Horizontal Induction?:
Which Cowl: (stock, Sam james, etc)
Prop: (Hartzell, Whirlwind)
Strobes/Nav Lights  fly LED's, etc)
Which Landing Lights: (baja designs)
Interior: (Aero, Flightline)
In addition, what mods would you suggest to the plane (gear stiffener, handle mods, switches, engine mods, EZ Cool)
I appreciate your input!
Exempt, but gladly paid VAF Dues for '18
Please excuse the dumb questions. I'm an FNG!
01-22-2018, 05:44 AM
yes to all, get that card warmed up
01-22-2018, 09:04 AM
Our Dream RV-7A
We are within a month (we hope) of flying ours. It was a QB project we bought, but ended up doing over much of the previous owner's work.
Penn-Yan modified ECI Titan IO-360, 9.5 to 1, converted from O-360, horizontal induction
Superior cold air sump
Dual P-mags (came with kit and engine)
Christen inverted oil
Airflow systems oil cooler
Sam James extended cowl with Bill Lane plenum
Modified Vetterman dual muffler exhaust (fits in SJ cowl with no cowl mod and reportedly provides better cabin heat)
Hartzell wide chord composite prop with extended "M" hub
Stein built Garmin G3X IFR panel with GTN-650, G5, Garmin A/P
VPX Pro (came with kit I bought, would normally use C/B's)
B&C 60 amp alternator
Classic Aero full leather interior
Aerosun VX, Suntail, with left wing Duckworks 50W HID (old eyes need lots of help)
Plane Schemers/Evoke Aviation paint (will be done after Phase 1)
Synergy Air build assist
Custom canopy jettison for aerobatics
EarthX battery
Numerous small mods and aftermarket upgrades
This was not a light weight, low cost airplane. It is what we wanted, though.
Best of luck with your build!
Krea Ellis
Locust Grove, GA
DA20-A1 "Princess Amelia" - gone home to Amelia Island
RV-7A Phase 2
RV-10 under construction at Synergy Air South
Reason: Added features
01-22-2018, 04:15 PM
Krea,
Thanks for the detailed reply. Would you happen to have a list of those "numerous small mods and aftermarket upgrades."? I have found it is those that really make the difference!
Are you concerned at all about some reported heating issues with the James cowl?
No dual alternator? Dual battery?
Who does the jettison canopy?
Thank you for your help
Chad
01-22-2018, 07:47 PM
I'll PM you tomorrow.
Krea Ellis
Locust Grove, GA
RV-7A Phase 2
01-23-2018, 09:22 AM
Go ahead and do the Super Tracks and Almost -14 mod while you are at it.
Ray
RV-7A - Slider - N495KL - First flt 27 Jan 17
O-360-A4M w/ AFP FM-150 FI, Dual PMags, Vetterman Trombone Exh, SkyTech starter, BandC Alt (PP failed after 226 hrs)
Catto 3 blade NLE, FlightLines Interior, James cowl, plenum & intake, Anti-Splat -14 seat mod and nose gear support
All lines by TSFlightLines (aka Hoser)
01-23-2018, 03:02 PM
Raymo, those just made the list. Both great mods.
Chad
01-23-2018, 03:27 PM
I grew up in Redding, that being said you may want a sunshade for that slider. Tip: drill the mounting holes for the slide and Velcro tabs before you install the plexi. That was nerve racking drilling after the fact. Some like the grab handles that mount on the front windshield bar, I just use the center post, longeron dies, Min 10 row oil cooler for Redding
01-23-2018, 06:02 PM
Brett,
I have done some work in your current neck of the woods. Retired cop from Vegas. Did some contract work for NVDPS.
Good call on sunshade (can you recommend one)? Longeron dies?? Link to grab handles?
Thank you!
Chad
01-24-2018, 05:54 AM
Originally Posted by SinCityJets
Brett,
Thank you!
Chad
I did the long shade https://kogersunshades.com/ and to bend the longerons http://bullerent.com/experimental/longeron-dies/ I did not do the handles, I just use the center bar, less aft stuff to get in the way of getting out.
are you at Benton? I still have fam there and visit every now and then. have a great day!
