Old 01-21-2018, 04:31 PM
Draker's Avatar
Draker Draker is offline
Default Aileron hinge bracket flush rivets inboard or outboard
Starting yet another thread on this topic. Looks like I'm at another "fun" part. Is there as of 2018 any prevailing view on which side of W-414 (the outboard aileron bracket) should be countersunk for flush rivets? I've searched here and have read a wide range of opinions:
1. Stick to the plans (flush head on outboard side)
2. The plans are wrong. Flush head should be on inboard side due to clearance issues
3. Van's told me the flush heads should be outboard
4. Van's told me the flush heads should be inboard
5. Countersink both sides for double flush rivets
I typically default to sticking to the plans, but since there has been lots of discussion on this topic, yet no clear consensus, I thought I'd seek out current VAF wisdom here.
Old 01-21-2018, 04:54 PM
RV6_flyer's Avatar
Default RV-8 Left Wing Build (last year)
For my RV-8 left wing build last year, I followed the plans and have Flush on the Outboard side per the plans image you posted.
25-years ago on my RV-6 slow build (flying over 20-years) the brackets came pre-built and appear to be double countersunk. I cannot see any rivet head on the flying airplane without doing some disassembly but I know there are rivets in that location.
I just walked the 18 steps from my house to my hangar to check both the flying RV-6 (it flew today with over 3,300 hours on the Hobbs) and the RV-8 left wing.
Gary A. Sobek
NC25 RV-6
Flying
3,400+ hours
Where is N157GS
Building RV-8 S/N: 80012
Old 01-21-2018, 05:09 PM
wirejock's Avatar
wirejock wirejock is offline
Default Aileron Hinge Bracket
On my 7, the one shown with the note works best if flush on the inboard side. Mine ended up double flush because I installed it per plan then later had to drill it and replace it flush on the inside. Actually works pretty good that way as it completely eliminates any interference issue.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Disclaimer
Old 01-22-2018, 12:32 AM
N546RV's Avatar
N546RV N546RV is offline
I did mine double flush.
Philip
-8 fuselage in progress (remember when I thought the wing kit had a lot of parts? HAHAHAHAHA)
http://rv.squawk1200.net
Old 01-22-2018, 12:40 AM
PilotjohnS PilotjohnS is offline
Default huh?
On my 9, which is nearly identical, the W414 brackets are not flush rivets (AN470), but the ones near the bearing are (AN426). I tend to put the manufactured head so it is easy to drill out.
John S
WARNING! Information presented in this post is my opinion. All users of info have sole responsibility for determining accuracy or suitability for their use.
Dues paid 2020, worth every penny
RV9A- Status:
Tail 98% done
Wings 98% done
Fuselage Kit 98% done
Finishing Kit 35% canopy done for now
Electrical 5% in work
Firewall Forward 5% in work
www.pilotjohnsrv9.blogspot.com
