Old 01-21-2018, 01:47 PM
sblack sblack is offline
Default Crimping wires together
I have 2 20 ga wires going to the same connection. Is it an acceptable practise to crimp them both into the same terminal?
Scott Black
VAF dues 2020
Instagram @sblack2154
Old 01-21-2018, 02:30 PM
Mark H's Avatar
Mark H Mark H is offline
Here?s a link to Bob?s notes at the Aero Electric Connection. Hopefully this is helpful. You should be fine with 2 wires to a single connection.
http://www.aeroelectric.com/articles...iplewires.html
Mark Hansen
Indianapolis, IN
RV-7A N896PS
Flying
vic syracuse vic syracuse is offline
Super Moderator
Yes, with the proper size connector.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 01-21-2018, 02:55 PM
Thank you!
Scott Black
VAF dues 2020
Old 01-21-2018, 03:07 PM
az_gila's Avatar
az_gila az_gila is offline
Thumbs up
it's even allowed in the manufacturer's data sheet
Page 8 - http://www.te.com/content/dam/te-com...1_QRG_PIDG.pdf
Gil Alexander
RV-6A N61GX - finally flying
Grumman Tiger N12GA - flying
