  #31
Old 01-21-2018, 06:48 AM
N941WR's Avatar
N941WR N941WR is offline
[quote=tomww;1233764]Do you really not realise your ground speed and MPG are due to a stonking great tail wind?[/url]
Do you realize those MPG numbers were calculated using TAS, not GS?
If I had used GS, the -9 is over 40 MPG and the -6, with a slight tailwind is at 28.1 MPG.
One other thing I noticef, the -9 is flying at 17.6 DA and the -6 is at 16.6 DA.
Impressive numbers for both aircraft. (Even though the -9 is the better aircraft for high altitude cruising.)
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
Old 01-21-2018, 07:11 AM
ChiefPilot's Avatar
ChiefPilot ChiefPilot is offline
Wrong. The EMS-D10 in the -6 computes MPG via groundspeed; it has no access to TAS data.
Brad Benson, Maplewood MN.
RV-6A N164BL, Flying since Nov 2012!
If you're not making mistakes, you're probably not making anything
bret's Avatar
bret bret is offline
Originally Posted by snoop9erdog View Post
Regardless of the model or the performance numbers.
Ditch the pole vault nosewheel design and be a real man.
Put the little wheel in the back...I changed my mind on my build to tailwheel. Hope I like it.
Uh oh....now I did it.
Do you have great BIG oversized tires on your truck also to compensate for.....
Old 01-21-2018, 07:32 AM
N941WR's Avatar
Stu,
See if you can arrange back-to-back rides in both, if you can find one of each with the same engine - prop combination.
That is the only way you can make an honest assessment of what is best for you.
Bill R.
SC86 - Easley, SC
Old 01-21-2018, 08:12 AM
snoop9erdog snoop9erdog is offline
Talking You guys are great
Well I knew I was headed to forbidden territory with the the tailwheel comment. Serves me right.
But....mission accomplished. I managed to get Captain Avgas to chime in. Nowadays, That's a rare feat.
The reality is that either model is sufficient. I personally prefer a 45 stall speed for various reasons.
I actually drive a piece of junk rusted out Toyota Tacoma that I have to keep the drivers side window cracked open so I can open it up from the inside because both door handles are broken....but that little engine keeps on purring. Not even sure if I could put bigger tires on.
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Worlds longest RV build...but getting there
Old 01-21-2018, 08:24 AM
I must admit though....I'm puzzled. In your signature, you have an 8 in progress, but you are are asking about a 7 or 9? Are changing?
I think a carbon cub would be fantastic....until you have to travel a long distance..so I hear you on that one.
Do a search on here for videos of a gentleman from Seattle who recently flew his red and white 7 to Alaska. One of the best videos I've seen to date.
Ed Avila
St. Johns, AZ (SJN)
N646A RV9
Old 01-21-2018, 10:27 AM
tomww tomww is offline
Impressive numbers for both aircraft. .......
Especial for the 9 that is going almost but not quite as fast as the 6.
Old 01-21-2018, 10:42 AM
N941WR's Avatar
More so when you consider that I wasn't at full throttle on that flight.
Bill R.
SC86 - Easley, SC
Old 01-21-2018, 10:55 AM
Dbro172's Avatar
Dbro172 Dbro172 is offline
Hindsight, wish I would have gone with a -9 Tailwheel. How about a -9 with a YIO-360-M1B with Smooth bottom cowl, maybe some big tires up front and a baby bushwheel in the back, that would be cool.
Derek Hoeschen
EAA Tech Counselor
RV-9A #92103 - N803DK
G3X, Superior XO-320, Dual Pmags, Catto 3B
www.mykitlog.com/dbro172/
1974 Bellanca Super Viking - N16AW - Flying
RV-8 #83565 - N184DK - building
1968 Mooney M20C - N6801N - Sold
1956 C-182 - N744W - Sold
Old 01-21-2018, 02:34 PM
StuBob StuBob is offline
Long story.
Stu F.
RV8
