Old 01-18-2018, 11:15 PM
mbauer mbauer is offline
Default PTT Switch Sticking-Fix?
On my last flight the PTT switch is sticking.
Anybody have this issue? How did you fix it?
Best regards,
Mike Bauer
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
Old 01-18-2018, 11:26 PM
Robin8er Robin8er is offline
I would just replace it, they are cheap. but I suppose you could remove it and try cleaning it.
RV-8 N695RA flying
Working on an RV-4
Born to fly, forced to work
Old 01-19-2018, 04:51 AM
Jesse's Avatar
Jesse Jesse is offline
I would replace it.
Jesse Saint
Old 01-19-2018, 05:18 AM
Robert Anglin Robert Anglin is offline
Default Same here.
The springs in them get bad a lot. I would get another good brand one and just change it out. Your call. Yours. R.E.A. III # 80888
Old 01-19-2018, 06:43 AM
rv8ch's Avatar
rv8ch rv8ch is offline
Default leave it
Nah, just leave it. We all love a stuck mic on the frequency.
Mickey Coggins
http://rv8.ch
"Hello, world!"
Old 01-19-2018, 08:22 PM
Default Ray Allen G205 Grip
After searching the web, looks like I have a Ray Allen G205 grip.
After reading the advice, anybody know which switch from Aircraft Spruce is a direct replacement for the PTT SPDT.
http://www.aircraftspruce.com/catalo...ickkey=3008651
or
http://www.aircraftspruce.com/catalo...hp?recfer=5745
Bought my Rv as already flying, don't have any paperwork or instructions on how to replace, anybody have the instructions? Did not find any on the Ray Allen site.
Best regards,
Mike Bauer
Mike Bauer
UTC -09:00 Alaska
Old 01-19-2018, 08:42 PM
ralph skorupa ralph skorupa is offline
Default Switch
Used a high quality one with gold contacts haven't had a problem since.
Old 01-19-2018, 09:11 PM
Originally Posted by RV8JD View Post
Call Ray Allen for replacement switches. Maybe this will help, from the Ray Allen site:
http://www.rayallencompany.com/RACme...ionsG2grip.pdf
Wow, Thank you! I did not find it on my search. Big Help!
Best regards,
Mike Bauer
Mike Bauer
UTC -09:00 Alaska
Old 01-20-2018, 10:21 PM
Wanted to fly today, clear skies and 20deg F. Decided to try a little spritz of remington gun dry lube. It worked fine.
Thought about using some silicone spray, research said, "not good for electrical contacts or plastic/foam rubber".
Made sure to spray the dry lube at a 90 deg side angle and not force any into the switch. Was able to fly without the PTT sticking.
Now planning to buy a complete new switch and replace, for now the temp fix is working.
Best regards,
Mike Bauer
Mike Bauer
UTC -09:00 Alaska
