Old 01-18-2018, 10:51 AM
steve murray's Avatar
steve murray steve murray is offline
Default What kind of Antenna is this?
I found this in the dark recesses of the hangar I rent. Is this a vhf antenna that I could install at my house to listen to airtraffic on my handheld ICom?
The picture is of one antenna on the pole, there are several up & down the pole connected in series... if it is a vhf antenna, could I use just one?
Steve
RV8 Flying since 2007 - Now for Sale
RV10 - Flying (Jan 2020)
Old 01-18-2018, 11:22 AM
rv7charlie rv7charlie is offline
https://www.google.com/search?q=inve...hrome&ie=UTF-8
Old 01-18-2018, 11:29 AM
I doubt that they are actually in series.
FWIW, you can make a serviceable VHF antenna for a ground station using almost anything that you possess that's made of metal, plus a BNC connector. Lots of Kitplanes articles over the years on making them.
Old 01-18-2018, 11:46 AM
DaleB's Avatar
DaleB DaleB is offline
I'm going to take a wild, slightly educated guess here.
If you found it in a hangar, and there are several interconnected assemblies like that on a pole, I'm going to guess it's a collinear VHF antenna, probably tuned in the VHF air band. It won't hurt to try using it as-is for receiving; I wouldn't want to use it for transmitting without some additional knowledge or putting it on an antenna analyzer.
Dale
Omaha, NE
Previous RV-7 project (sold)
