You can set the timing as you mentioned or you can set it to 20? BTC with either the EICAD program, free from Emag, or with the EICommander.
The you set it to TDC when timing the P-mag.
If you elect to configure the P-mags with the EICAD program, then you leave the jumper out.
Check you PM's.
Bill R.
O-360 w/ dual P-mags
SC86 - Easley, SC
www.repucci.com/bill/baf.html
