Old 01-14-2018, 02:11 PM
StickNRudder StickNRudder is offline
Default Will helmet (or head) break the canopy?
With my seat a comfortable height for normal (blue-side up) flying, I find when I do neg g maneuvers my helmet hits the canopy. I cinch up the belts but it still happens. I have a slider and was concerned if I could crack the canopy?
If I am not going to be doing aerobatics, I don?t wear the helmet and my head doesn?t hit even in turbulence. The things I have thought of: lower the seat but that will restrict forward visibility, pad the helmet, don?t wear a helmet, or don?t worry about it.
Rick Woods
N5427W == Jack, Hank, Barbara, and Rick Woods.
RV-7
Flying, but not done, never done.
Old 01-14-2018, 06:40 PM
schaplerrh schaplerrh is offline
Do you have a ratchet belt? Removed same from right side at her insistence but now can't secure passengers anywhere close to my belt for acro.
Old 01-14-2018, 10:49 PM
I have a Crow 5-point harness. I thought it would be ok. It sounds like a ratchet style might be needed. You selling the one you removed?
Rick Woods
RV-7
Old 01-15-2018, 09:54 AM
ppilotmike's Avatar
Default One Data Point
I have heard of one occurrence, here in Colorado, where a very seasoned RV-6 pilot smacked his head during turbulence and cracked his slider canopy enough that it needed to be replaced. That being said, I believe the canopy had flown for many years before this occurred. Although it's always been hangared, it sees a lot of flight hours too.
Mike Rettig
VAF Dues Current
RV-10 - Working on engine / prop installation
Old 01-15-2018, 11:53 AM
wirejock's Avatar
wirejock wirejock is offline
Default Shoulder straps
I wonder if it is due to the way Vans shoulder straps route from behind instead of below.
Driving a race car, the straps route down. The really cinch you down in the seat.
Larry Larson
Estes Park, CO
wirejock at yahoo dot com
Donated 12/01/2021, plus a little extra.
RV-7A #73391, N511RV reserved (3,000+ hours)
Empennage, wings, fuse, finishing kit done. Working FWF
Disclaimer
Old 01-15-2018, 12:19 PM
Shoulder straps from behind is the recommended approach, since a downward angle puts a downward compressive load into the spine in a crash.
To prevent moving upward in aerobatics, tighten that seat belt.
Ages ago, I learned aerobatics in an open-cockpit airplane over the ocean. The first thing we'd so was roll upside down and roll back upright. Then we'd tighten our safety belts as much as possible. We repeated this and if necessary, we tightened again. Having no canopy and a cold ocean underneath made this seem important.
Dave
Old 01-15-2018, 01:23 PM
wjb's Avatar
wjb wjb is offline
My old acro instructor said to to tighten the ratchet until your pelvis cracks, and then tighten it one more cycle for good measure. The lap belt really needs to be tight to keep from moving up/down.
Bill Bencze
N430WB RV-7 @KHAF, Flying 100+ hrs
VAF 2021 donation happily made
Old 01-15-2018, 02:06 PM
I see the problem, thanks. I really tightened the shoulder straps but left the lap belt at it?s normal tension. Next week I?ll try again.
Rick Woods
RV-7
