Old 01-13-2018, 04:49 AM
vic syracuse vic syracuse is offline
Super Moderator
Originally Posted by alpinelakespilot2000 View Post
Not sure if anyone has already said this, but the difference in weather before and after after July 4 in this part of the country is pretty significant. Before the first week of July the weather is wildly variably. After the 4th until after Labor Day it's quite a bit more consisently good for flying (or anything else outdoors).
Good luck planning your trip. You'll enjoy it for sure!
Yes, that's been our experience as well. We leave from Atlanta on or about the 4th of July.
Vic
Vic Syracuse
Built RV-4, RV-6, 2-RV-10's, RV-7A, RV-8, Prescott Pusher, Kitfox Model II, Kitfox Speedster, Kitfox 7 Super Sport, Just Superstol, DAR, A&P/IA, EAA Tech Counselor/Flight Advisor, CFII-ASMEL/ASES
Kitplanes "Unairworthy" monthly feature
EAA Sport Aviation "Checkpoints" column
EAA Homebuilt Council Chair/member EAA BOD
Author "Pre-Buy Guide for Amateur-Built Aircraft"
www.Baselegaviation.com
Old 01-13-2018, 06:42 PM
keitht keitht is offline
Default Flying in Alaska
There is some really good primer info on the FAA website with links to more info.
The weather here on the Pacific coast in Wa is similar but not as intense as the weather in western BC and Alaska. Every summer there are fatal airplane accidents involving pilots flying through the cascade passes under cloud covered mountain peaks, gettin lost and ending up in a box canyon with no way to turn around. Some are high time pilots but with little experience in the actual conditions. An old experienced pilot at my local airport who flies a supercub up to Anchorage for the summer every year flies the trench route or the more easterly route - safest, better weather and IFR ( I follow roads). Western Wa is heavily populated compared to western BC and Alaska and yet some of the airplane wreckage in the Cascade mountains isnt found until the following year despite intensive searches. Being in a single engine flight of one on a direct route over large expanses of unlandable desolate terrain is taking a big unnecessary risk even if it is in daytime severe clear conditions. Mountain flying experience is really a big advantage for avoiding getting suckered into making bad decisions. Heading into weather that is going down and having it close in behind you with cloud down on the mountain tops is no fun. Wasn't in the forecast but when dewpoint temp spreads are 1- 2 degrees it doesnt take much and that can be typical for northern pacific coastal regions in the summertime. Flying to Alaska with a group that has at least a couple of pilots familiar with the route and in similar performance aircraft is a good way to get started. Its all about the journey and making it fun so it needs to be VFR and taking the time to wait out the weather. Having the instrument rating in Alaska in a light single is, in my view, for getting out of trouble not for getting into it. The scenery is like no place on earth on a good day.
KT
Old 01-14-2018, 08:10 AM
RV7ator RV7ator is offline
The biggest problem flying in Canada is US CBP. (BTW, order your decal months before you intend traveling, and make sure your passport is and will remain valid throughout your trip.) Besides the eApis folderol, you must PHONE the port of entry to make an appointment for customs. Ergo, you must have cell coverage or access to a landline. Several times, my cell couldn't access the local network, and I've had to find some office open on the airfield with a landline, AND have internet to file the ePISS plan. Ketchikan knows wx can screw up arrival times, and they've been most accommodating, but don't surprise them. Northway's a pain since the officer must drive 2 hours from Tok even though Northway's the port. Go figure. You do need a phone to call Canadian customs upon landing, but most ports have a landline. Check service hours, though, at your intended port. Also, both customs work with local time not Zulu, so you have to know who's in what time zone for determining arrival time.
Forget firearms; added weight and complications. The mosquitoes will get you before the bears.
The flying part is easy.
John Siebold
Old 01-14-2018, 10:10 AM
guccidude1 guccidude1 is offline
Default Alaska adventure
I noticed that no one mentioned MOSQUITOES. Better take copious amounts of repellent. Those suckers are big enough to have tail numbers. Just sayin'. Dan from Reno
Old 01-14-2018, 10:50 AM
mfleming's Avatar
mfleming mfleming is offline
While it is true that the interior portions of Alaska and the Yukon usually enjoy cavu weather in the summer (except for wildfire smoke), it is not what I remember for the Southcentral and Southeast regions of Alaska.
These coastal regions can have wonderful weather after July 4th but it seemed more often than not, after the 4th, the weather would take a turn for the worse.
After living and flying in Alaska for over 30 years, I'm just saying, don't be surprised if the weather turn IFR in a hurry, especially in the Southeast area.
Another thing, the forecasting models don't seem to work nearly as well in Alaska's coastal regions as the do in the lower 48. There's been more than one tourist that's had a bad ending to their Alaska flying vacation due to variable and fast changing weather.
Michael Fleming
Joseph, OR
sagriver at icloud dot com
RV-7 Slider #74572
Started 11/2016
Empennage completed 11/2016 (sans fiberglass)
Ailerons and flaps completed 3/2017.
Wings completed 12/2017
Started on QB fuselage 01/2018
Donated for 2020 and so should you
Old 01-14-2018, 11:04 AM
mfleming's Avatar
Originally Posted by Veetail88 View Post
I'm planning an adventure/sight seeing trip this June or July to Alaska via the Seattle area. I've never been up in that corner of the world nor do I have mountain flying experience.
I know there are lots of you that have done similar and I'm wondering if you all might share some routing and safety tips/suggestions, "you don't want to miss it's", things to see, places to stay and what's the best time of the season weather wise to make such a trip.
Planning a 9 day round trip.
Thanks ahead of time for your help!
Oh, also, a side arm would be nice for forced landing/hungry grizzly bear defense would be nice, but I think it's not legal to carry across the line or in Canada. What say ya'all about that?
This is NOT the route I would suggest for your first trip to Alaska. The trench is also not on my list of recommended routes for a first trip without mountain experience..
With no mountain flying experience and this being your first trip, I would recommend you follow a route that follows the main road system through the interior.
The weather will be more friendly and the stops more frequent.
The coastal route shown and mountains you must cross are very unforgiving.
You route combines all of this for a first trip. Do yourself a favor and take the more forgiving path...you'll still have tons a fun.
Michael Fleming
Joseph, OR
RV-7 Slider #74572
Started 11/2016
Old 01-14-2018, 03:45 PM
mbauer mbauer is offline
Default Orcas Island to Petersburg
Hi,
Flew a similar route last May (2017).
Flew from Orcas Island, WA to Petersburg, AK. 760 Statute Miles, 5.2 hours used 29-gal of fuel. RV-6 160hp. Throttled back to 2100 rpm.
Over the Memorial weekend 2017, weather was clear, a tailwind at my cruise altitude helped, ave 146 mph at 12,500 ft. Yes, used oxygen.
Air was smooth, no bumps. Not many places to land!
Fuel at Petersburg is lowest price along the coast, however usually not open on weekends, call ahead if you plan to head there.
Planning a trip over the coast means you will need to flight plan and watch weather months in advance.
Alaska has weathercams available that are located in many mountain passes, and most importantly at many airfields. here is the link: http://avcams.faa.gov/
Use the cams to verify your route weather, lots of them available along the coast as you can see!
Another useful tool for winds: https://www.windy.com/?60.630,-150.870,8,m:fl4aW1 You can look several days ahead by going to the calendar at the bottom.
I use weatherunderground for my local weather, it is the most accurate I've found locally. https://www.wunderground.com/weather/us/ak/kenai/99611
One search performed, type in weather history for the route naming different towns along the route. Lots of sites popped up with past history month by month, you can see averages that show rain, temps etc.. Helps give an answer to one of your questions about best time to fly.
For a direct overflight from the US over Canada to US with no stops, I filed an IACO flight plan per instructions. When I left Orcas Island, had to fly to the North to activate with Bellingham RCO. At that time was told the type of plan I filed was not available yet due to equipment not in place, they converted to a domestic flight plan.
Request flight following for the route if you fly the one I did. Using flight following helps with the restricted areas you will fly near/over. The biggest help was when entering Canadian Airspace, must be in contact with ATC.
Controllers were pleasant to talk to and they know where you're at if you have problems!
Expect some vectoring around Victoria and Vancouver airspace. I planned to climb to 12,500 ft during this transition, they had me hold at 8500ft, fly to the west to clear some jet traffic. I was at Comox before they told me to resume my own navigation. This took me a little off course.
Next time I will climb to my altitude before attempting the border crossing...
If you plan on stopping in Canada, you will to check out this link for more info: https://travel.gc.ca/returning/customs/entering-canada
All in all, was very lucky on my day of travel. Knew months in advance of what the weather was going to be by constantly checking the above sites. Planned on a 4-day window 6-weeks in advance. Weather was as forecast, the actual day I flew! How lucky is that?
Hope you enjoy your flight!
BTW you will need specific survival gear, here is a link, however it is not the one I was hoping to find: https://www.bladeforums.com/threads/...by-law.118124/
Notice firearms are no longer required. Handguns will get you in trouble in Canada. I used to use a folding long gun .22 cal for my required firearm. This type will also get you in trouble in Canada.
Don't call a flare pistol, a pistol. It is a hand held pyrotechnic signaling device!
Best regards,
Mike Bauer
Mike Bauer
N999SN 1998 Syd Nelson RV-6 (purchased 2017)
UTC -09:00 Alaska
Old 01-14-2018, 04:01 PM
Originally Posted by joe_rainbolt View Post
I've been thinking about this trip myself ever since completing my 48 state tour last summer. Of particular interest to me is the initial leg from northern WA to Ketchikan AK. Skyvector.com shows the shortest route from Orcas Island (KORS) to Ketchikan (PAKT) as 515nm. LOP at 7.5 to 8 GPH yields about 30 gal for the trip assuming we could manage 140kt or better over the ground. A ten gallon reserve at the destination does not seem excessive considering the location.
So the leg seems do-able, weather permitting, but am I missing something? Is it advisable? How much trouble would I be in if I had to divert to a Canadian airport without first having cleared customs at the border?
Hi Joe,
I've done a similar route last year. I flew to Petersburg instead of Ketchikan. Reason, cheaper fuel and no GA landing fee. My route allowed using Ketchikan, and Wrangell as alternates if fuel became an issue. Wrangell was right under my route and Ketchikan was to left.
Best thing to do is use flight following for this route, if problems develop they know where you're at and declaring an emergency will get immediate help. Flight following also helps with the restricted areas along this route.
Best regards,
Mike Bauer
Mike Bauer
UTC -09:00 Alaska
Old 01-15-2018, 11:29 AM
joe_rainbolt's Avatar
joe_rainbolt joe_rainbolt is offline
Hi Mike, Thanks for all the great links and advice. It seems that I have some homework to do.
Joe Rainbolt
RV-7A slow build complete 4 July 2016
Visited all 48 contiguous states July 15-29 2017.
Blog: www.roughandreadyaerospace.blogspot.com
Old 01-19-2018, 09:34 AM
Jesse,
9 days are not enough for your planned Alaska route plus sightseeing. If you can?t add extra days just fly north then intercept Alcan and go see Greg. British Columbia has it all. I?ve flown coastal, the Trench and more eastern route and all of them have their own challenges. Tons of great suggestions above thanks Bob, both Mikes and others. I am planning another run starting on Memorial Day hoping the weather gods will be busy with North Slope...
